Nice work Bob.
I’ve had some progress this afternoon, but it was a case of two steps forward.....
I’ve managed to sort out the motor mount and rough alignment with the propeller shaft ready for bonding in. I had purchased a rigid coupling to help align before switching to the flexible one. However my fixed coupling isn’t straight! Ie holes at each end aren’t centred, so it’s of no use at all
I am eyeballing it instead
Connected all the electrics up and got my son to pull the trigger whilst I held motor and prop tube in place. Wow it’s going to be fast! I think....
On the down side my Javelin took a tumble and landed nose first on the carpet! Broken off the rubbing strip!
Any good ideas on how to fix this effectively?
I’m thinking I’ll need to remove a reasonable section and replace it. A bit annoying as the strip was in good shape!
Never mind... shouldn’t have propped it up where I did. Little voice in my head said it wasn’t the best idea!
