Author Topic: Steam Whistle to servo setup  (Read 3231 times)
morfa
  • Model Boat Mayhem best forum ever!
    • Morfa
« on: August 26, 2020, 10:02:02 pm »
How do setup a steam Whistle attached to my boiler to a servo. Is that the way to do it or some other way?
It has a little arm that has a spring that allows it to pull forward and spring back after you release it after "playing" the whistle.
http://www.morfa.ca/steamwhistlev1.png
Thanks,
Jerry C
Re: Steam Whistle to servo setup
« Reply #1 on: August 27, 2020, 12:49:23 am »
This is how I did mine after I stripped the servo gears when the pull line was too short. I made the compression spring out of a biro spring and a paper clip, it’s a miniature copy of the mooring springs that yachties  use.
Jerry.
morfa
    • Morfa
« Reply #2 on: August 27, 2020, 01:11:18 am »
Brilliant, will give it a go.
Diolch
Jerry C
« Reply #3 on: August 27, 2020, 01:19:16 am »
Croeso
rhavrane
  • Steam passionate collector
Raphaël
morfa
    • Morfa
« Reply #5 on: August 28, 2020, 02:38:21 pm »
Thanks, will study what you did and see if they work for me.
Cheers,
morfa
    • Morfa
« Reply #6 on: August 29, 2020, 03:57:05 pm »
Guys,
Thanks for all your advice and inspiration. Here is what I did after looking at your work/suggestions.
In action - http://www.morfa.ca/steamwhistleinaction.mp4
Mark T
« Reply #7 on: August 29, 2020, 04:01:25 pm »
Hi Derek - sorry I never saw your post but it seems that you have got it sorted  :-))   Does the valve need to be held shut by the servo or is it self closing?
morfa
    • Morfa
« Reply #8 on: August 29, 2020, 04:12:56 pm »
The whistle has a little spring that self closes but I have not figured out how to set the micro servo to "open/close".
I have to hit the servo channel (3) once to play the whistle, once to close it.
Any suggestions. I was just thrilled to get this far.
Mark T
« Reply #9 on: August 29, 2020, 04:17:27 pm »
Hi Derek I think if it works and works well You've got a great solution.  Can I ask what make the whistle is as it looks very nice
morfa
    • Morfa
« Reply #10 on: August 29, 2020, 04:47:14 pm »
It is - I got it with my steam plant from MSM out of Australia.
« Reply #11 on: August 29, 2020, 11:20:30 pm »
You can also get that lazy bearded Deckhand >>:-( [who is getting a free ride] to swap seats....then link his movable arm to a miniature chain connected to the whistle, then have this hidden back to the servo
Too many of the Crew get an easy job......I am trying to get this Bilge Rat to open a valve  {-)  , or pump some water  :kiss:
Jerry C
« Reply #12 on: August 30, 2020, 12:02:33 am »
That works but looks a bit bulky. You could simply replace the rod and clevis with thin fishing line including a spring servo saver like I showed you before somewhere in the line. It keeps the line taught but prevents servo locking and stripping the gears.
Jerry.
rhavrane
« Reply #13 on: August 30, 2020, 12:04:00 am »
Bonjour,
Derek, I like your crew,
Derek 2 ok2 , you can hide the little servo in a small wooden box and, as the whistle valve is auto closing and facing its servo, I would kindly suggest you to use a thin cable or chain instead of your big metal rod.
Raphaël
« Reply #14 on: August 30, 2020, 12:43:02 am »
Yes .......many ways to disguise a servo as a wooden box.......then coaching the Crew to earn their passage  {-)  .... Derek
morfa
    • Morfa
« Reply #15 on: August 30, 2020, 01:48:30 am »
Planning a box, just too many chores to do before I can get back to my love - Cariad.
Will look at the "wire" option too!
KNO3
« Reply #16 on: August 31, 2020, 08:23:03 pm »
A piece of string or a thin chain is really all that's needed for a steam valve. A spring servo saver is completely unnecessary in this application, since the whistle actuation requires little force and is only done momentarily. But I have to say your servo saver and rod look nicely made, I would reuse them for the steam valve, where they would be more useful.
morfa
    • Morfa
« Reply #17 on: August 31, 2020, 08:28:28 pm »
Thanks, going to play with it again and simplify the process.
A string might make the box setup I plan easier and flexible.
morfa
    • Morfa
« Reply #18 on: September 02, 2020, 07:43:42 pm »
Getting closer. Did a redesign to make it a little simpler and added a box. Will fine tune the box and add a little side piece to hide the servo arm coming out.
But satisfied that it works well.
www.morfa.ca/steamwhistleinactionrevised.mp4
Cheers,
KNO3
« Reply #19 on: September 03, 2020, 12:34:00 am »
Looking good!
southsteyne2
« Reply #20 on: September 03, 2020, 01:13:41 am »
I use very fine fishing leader which is barely visible and also goes around tight corners works great.
morfa
    • Morfa
« Reply #21 on: September 03, 2020, 01:25:56 am »
That was my first choice but my rod is at my cottage, and I had some thin wire in my kit.
Good suggestions - thanks
Page created in 0.345 seconds with 18 queries.
