Author Topic: La Canicule .  (Read 4276 times)
KBIO
La Canicule .
« on: October 18, 2020, 10:39:49 am »
Hello!
Last winter , I decided to build something to fit one of my Steam Assy sleeping on the shelves. Caton/2 from MH& B and an old Cheddar return flue boiler. Micro burner BOBINO.
So I asked my friend Rookie to draw me something looking like the Opal (M.Baylis) . Rookie have two passions in his life : drawing & whiskey . %)
Although there is some differences, the launch is very similar of the original one.
You'll learn later why I call her "La Canicule" although some have already guessed!
Let's go! :-)
First gluing the ??? I realize that my vocabulary is poor in English. Do not hesitate to teach me.
Cheers.
Mark T
Re: La Canicule .
« Reply #1 on: October 18, 2020, 11:02:55 am »
Good luck with this build - I'll be watching this one  :-))
Re: La Canicule .
« Reply #2 on: October 18, 2020, 12:09:49 pm »
OK....you know I watch your postings on the other FROGGY web sites {-) , but please KBIO,.....also post them here for all to see! .....
PS....I always thought rookie78 was as they say 'Tea-Total'.......which means he does not partake in the Demon drink  >>:-(
KBIO
Re: La Canicule .
« Reply #3 on: October 18, 2020, 01:33:58 pm »
Hello!
 I already made a mistake. :embarrassed:
The Canicule is mounted withe a 3CC JMC and a Regner Boiler..... FORGET the Caton2 and the Cheddar boiler which are in another boat..
You see Derrek , I probably undergo my friend Rookie vapors of the demon drink (and I share!) . I count on you to correct my posting as you know them all on the froggy forum! :-))
Keep safe!
KBIO
Re: La Canicule .
« Reply #4 on: October 20, 2020, 11:32:51 am »
Hello!
After cutting the frame and the keel, it is time to line up every thing on the rig .
Then not forget and preparing for the propeller implementation and line in.
Also, I run a plank alongside the hull from up to bottom to ensure that it is smooth with no bumps in & out.
When all is in place, I can start to glue the planks next ! :-)
Regards.
belli
Re: La Canicule .
« Reply #5 on: October 20, 2020, 09:39:10 pm »
Bonjour KBIO,
J'ai de nombreuses questions...
Were the drawings done with CAD or were they drawn by hand?
What is the overall size of the launch (approx)?
Why are you drinking whiskey?  Do the French not have some fine spirits of their own?
There are many more but as your build progresses I am sure I will have my answers.
 Please post many photos!
Bellisimo!
KBIO
Re: La Canicule .
« Reply #6 on: October 21, 2020, 04:19:22 pm »
Hello!
When everything is held in place, square and line up properly, I check the edge of each frame and file it to make sure that the plank will stick on the whole side.
Then I braze the etambot bracket and I glue it with epoxy in place in the keel. I shape each end of each plank by removing < than 1/3 to allow a complete covering without dirty patches. I do that by taking 4 or 6 of them together and sand paper them on my belt sander. I then do the same on the full edges inclining by +/-15°
When this is done, I sand paper the hull until I do not see any default : bumps or hollows. There should not be any problem if the work has been done properly in the first place .
Then, when finished and sand papered once more, in a can , I mix white glue with dustwood and a bit of water to spread it all over the inside and the outside.This is ugly but it fills up the little gaps left.
Letting dry for 24H00 or more! And back to sand paper again. grain 80/120.
Following step is to apply a 25 g/m2 of fiber glass sticked with 50 g of resin and enough methylated spirits to have it as fluid as water . I apply the mixture on the cloth with a round paint brush and I flat the folds. I spread  it on the outside only. One layer is enough.
At this step, some will ask why to apply fiber glass ? There is so many judicious argument in this matter that I will give only my personnal reason.
- I build my hulls with a 2mm thick wood planks. I sand paper a lot and there is only 1 mm thickness left at some places . So the tissue reinforces without adding too much weight. < 70 g.
Finally  I apply the two-componants patty with a small flat piece of  rubber 5mm thick. If the job has been done properly in the first place, it is a pleasure to apply a thin film of it. No sweat to sand paper …. again with grains from 120 to 250.
At the end she weights less than 700 g.
Time to glue the supports for the steam plant inside the hull and to go for painting.
   -They are made with CAD from pictures and photos. What is the overall size of the launch (approx)?
   - She is 113 cm long by 20 cm wide. The draught is only 3 cm . The deepest being the bottom of the rudder bracket.Why are you drinking whiskey?  Do the French not have some fine spirits of their own?
   - LOL! Some french people are still open minded and appreciate cultural exchanges between friends ! I avoid people drinking only Coca!
Note: The prime goal was to build a launch more or less, copied on what Martin Bayliss does. I found out that there is not too much difference between the Topaz and the Opal , so we could use the same drawing. First we worked on a kind of  Topaz.   The building is different as well as some details  : the bow for example is rounded and some others. No need to be an expert to find out that they are different boats.
The pleasure being to build rather than to buy , we asked some informations to Martin that he kindly answered. Then Rookie , the bottle on the left side , the glass on the other side and the screen in front worked it out . This guy is a genious engineer as he thinks of everything.
You ask him to draw you a simple swing for your kid and he comes back to you the day after , with a complete drawing of Dysney World!! :-))
We’ll talk of the (copy) Topaz in another post.
That’s all I have to do these days.
Thanks for you interest.
Regards.
KBIO
Re: La Canicule .
« Reply #7 on: October 21, 2020, 04:39:28 pm »
Good evening.
Some more pics to help following up.
Kind regards.
KBIO
Re: La Canicule .
« Reply #8 on: October 23, 2020, 07:53:48 am »
hello!
I pass over the drudgery of the painting and present right away the more interessant work.
The empty launch.
Presentation of the steam plant.
JMC 3cc / Regner boiler
KBIO
Re: La Canicule .
« Reply #9 on: October 23, 2020, 08:07:32 am »
More!
The fitting of the steam plant inside the hull and trials in the kids swimming pool.
I switched off evrything after 30 min @ 1000 RPM - 2.5 b inside the boiler.
Propeller 60 mm
KBIO
Re: La Canicule .
« Reply #10 on: October 24, 2020, 07:37:28 am »
Hello!
Everything is fine and this launch needs a bit of finish and details.
KBIO
Re: La Canicule .
« Reply #11 on: October 24, 2020, 07:44:08 am »
And a few last shots to end up with this post ! ok2
And a quick video to show her floating !
https://youtu.be/Fkhy3hUfl9o
Have a nice weekend!
Regards.
Re: La Canicule .
« Reply #12 on: October 24, 2020, 08:49:32 am »
I didn't realise your feet were so small KBIO........ ok2  ..................
This appears to be a wonderfully aggressive pitch steam propeller.......what is the vessel weight?, & how does the JMC3V handle it?
rhavrane
  • Steam passionate collector
Re: La Canicule .
« Reply #13 on: October 24, 2020, 10:10:53 am »
Bonjour,
Opal is a very thin launch, a 3 cm3 is almost too much for her, she will be fast but will perhaps loose a part of her autonomy.
My firnd Alain has one, here she is based on the full MH&B kit:
https://www.youtube.com/watch?v=FFDUHE-z80Y and on the water https://www.youtube.com/watch?v=GYHqMWsxXiI  and she sings  :-))
Raphaël
Mark T
Re: La Canicule .
« Reply #14 on: October 24, 2020, 04:24:27 pm »
KBIO - I think that is a very beautiful boat that you have made there.  It must have taken you quite a long time to complete but the result is fantastic  :-))
KBIO
Re: La Canicule .
« Reply #15 on: October 24, 2020, 07:04:13 pm »
Hello!
Thank you Mark! I have to  say that I enjoy following your post on your tug too.[size=78%]Always something to learn ![/size]
Yes Derek, the propeller is a Raboesh that I twisted a bit to give more pitch. How much ? .... some !!;-))
 I guess that I increased the slippage a lot , but without investigating more, it woks fine. No idea of the RPM in the water though!
It keeps the boiler pressure up to 3b when I am "Full Ahead" and the speed  seems OK  ! So ....Sail @ fun !
The launch weights 3.9 kg with all fluids and gas = all wet and full  ! ;)
Thanks for your kind attention.
Regards.
KNO3
Re: La Canicule .
« Reply #16 on: October 25, 2020, 07:36:58 pm »
Nice work! Please tell more about the performance. Or do you have a video showing full speed?
I was told by Mr. Regner (when he was alive) that the boiler model you have is very powerful and would steam every engine in the Regner Range. So a 3 cc engine should be piece of cake :-)
KBIO
Re: La Canicule .
« Reply #17 on: October 26, 2020, 04:47:35 pm »
Hello KNO3.
The video link that I give above shows the best I can get.
Just notice that there is no power loss when turning sharply .
To increase the speed ,  I need to increase the pressure over 2.5b, and fully open up the steam valve to the engine. The effect will be ; bigger steam consumption with  more RPM and ….. increase of  the bow wave  , so more water resistance! This is where the problem stands!!) .
At he end , I’ll have a negligeable gain of speed but a bigger steam consumption. The faster we go , the bigger the bow wave is and the gain is nil ! Marine engineers as familiar with this problem. There is a critical speed that we cannot go over in our available range of  power.
But as long as the boiler pressure remains steady  and the speed look realistic , that fits me well!
Before Manfred came out with this new boiler, he had two types of boilers on his catalogue.
The small ones to feed Lily’s and Piccolo’s type engines = +/- 2 cc to 4 cc , and single & double burners(pic below) ones for the Neptune engine = 11cc and above.
When he died, they stopped the production of the big boilers as there was probably not enough demand .
Now , when we compare the « Kessel Maxi » (like mine) and the « Kessel compact » you can see that the difference in size of the furnace is the double on the « Maxi ».
https://www.regner-dampftechnik.com/dampfkessel
Without entering into calculations,  the heated surface (estimated = 1.70 dm2) is much more larger than the « Compact » ’s one , and , obviously produces much more steam  .
The Compact boilers are good for Piccolo types engine ( +/- 4cc) , so the « Maxi" is far more than suitable for a 3cc engine ! (quod erat demonstrandum)[/size].[/color]
May be good to calculate how it behaves with the new Neptune  = +/-11cc
 I know only two suppliers manufacturing BRASS boilers ; REGNER & SAÏTO
All the others are COPPER made. If anyone can tell me why , I would appreciate.
(I do not consider Mamod, Wilesco and similar lwo pressure vessels which are quite different of what we work with)
If I may say so, Regner overheats the steam out of the boiler by passing through the furnace. The engine steam inlet then , temp is far above what it is needed for an « honnest » overheated saturated steam .
Too hot steam may bring some problems on O’rings, lack of lubrication, and as I’ve seen it, melting tin soldered connections.
I do not like the flare touching the steam line. A couple of loops inside the chimney is more than enough to overheat the steam by some °C.
Best regards.
Re: La Canicule .
« Reply #18 on: October 26, 2020, 06:33:47 pm »
The Model Power Boat Association (of great Britain) do not recommend boilers made of brass (although we will test to a maximum of 20 psi). the main reason is that brass is an alloy and depends on the bushes and fitting you will get "leaching and a reaction between materials, so for a higher pressure it is a no no. Copper boilers with due care and running at high pressure will last for at least 90 years as I am still using my grandfathers boiler (and engine both built in 1928) and it runs at 120 psi (8.2 bar for my friends over here)
rhavrane
Re: La Canicule .
« Reply #19 on: October 26, 2020, 06:53:44 pm »
I'm in tune with Phil, I was taught that brass is an alloy of copper and zinc which, over time, tends to reorganize itself at the level of the atoms which can ultimately weaken it. As they get older, some have seen micro cracks appear; Having said that, I don't know if this really affects our level and the operating pressures we apply to our boilers. I have a 30 years old home made brass boiler in my tug Côte d'Emeraude and it is always operational :
https://www.youtube.com/watch?v=tSOSj89BY_M
Raphaël
JimG
Re: La Canicule .
« Reply #20 on: October 26, 2020, 07:53:36 pm »
Brass in contact with water will tend to leach out the zinc at the surface especially if the water is even slightly acidic. This will embrittle the brass which can lead to cracking under pressure, this is why brass is normally only used for low pressure boilers. This is why higher pressure copper boilers use bronze fittings as the tin in bronze is much less reactive than zinc so won't leach out.
Jim
Dundee Model Boat club
Re: La Canicule .
« Reply #21 on: October 26, 2020, 08:39:44 pm »
Indeed Jim, brass boilers at low pressure will last for decades (a lot of the very early ones used pure lead solder !!!)
Definitely not for any pressure higher than 20-30 psi....and of course always do a little inspection before use on any steam plant
Safety first as always  :-))
KBIO
Re: La Canicule .
« Reply #22 on: October 27, 2020, 07:57:06 am »
Hello!
Thank you for this clarification!
Funny to underline that this decision of using brass comes from two country who have the repute of manufacturing long lasting @ reliable products!
Life goes on!
Regards.
carlfmiller
  • Model Boats + Model Trains + Model Planes!!
Re: La Canicule . and Congratulations
« Reply #23 on: October 29, 2020, 05:36:30 pm »
KBIO, I enjoyed your post of building La Canicule and congratulate your excellent craftsmanship. What a quick romp through a complicated build!  Fun to see this technique and I was so surprised you could use white glue and dust to fill the planking and make the hull smooth. Maybe I read too fast, but what wood is used for the planking? The video is nice and I have to say again what great job you did.
-Carl
KBIO
Re: La Canicule .
« Reply #24 on: October 30, 2020, 08:04:54 am »
Hello Carl!
Thanks for your kind comment.
The sandpaper dust is taken out of the belt sander . It is the same wood of the hull.
The proportion of the glue and sandpaper dust is 50/50 . Then I pour water untill I have a soft, just before to become liquid paste.
I pass it on the hull with a hard paint brush and I eventually squeeze the "paste" in between the slits with a plastic card .
(Your wife's Visa card is fantastic for this purpose! %) )
You allow some time for the glue to impregnate the wood and the dust to stick and when it is hard , then, you  sand paper from 120 to 250 before to apply the bi-component putty and eventually fiber tissue at the end.
The wood I use is :
- 5 mm birch plywood for the frame  and the keel ( 5mm x 2 sticked together to have a 10 mm one)
- 2 mm x 8 or 10 mm x 1 m poplar sticks for the hull.
Easy to work out and sand papers!
As we are locked down in here now, I'll have time to present some of my boats I made. Next one being the "kind of" Topaz scratch build.
Have a good day and keep safe!
Page created in 0.028 seconds with 17 queries.
