Thank you all, I will admit that I had to look up what Bravo Zulu meant, every day is a school day, your support and well wishing is appreciated. Well what a difference a few days make, here is the lake one week after HMS Darings maiden voyage! No chance of being back on the water until the weed cutting and clearing has taken place.
I like to be straight with you and having reflected on the maiden voyage, whilst it was a success, in that we have a boat that looks and behaves properly, the ballast and stability were fine, the electrics, radio control, engines and boiler all worked, there is definitely room for improvement in terms of performance. Another positive is that the down time due to the weed will give me time to implement a few changes. So this is not the end of our voyage together, there is more to be done.
The issue is one that some of you, along with myself have suspected. In my case I probably didn’t want to believe it, I just wanted to get HMS Daring on the water and prove that she worked - which we have now done, so now its time to face the issue which is, we are not making enough steam fast enough. Its an age old problem faced by many steam boat builders. The boiler is a well made return flue boiler and is efficient in that very little heat leaves via the chimney, so the heat from the burner is going into the water. What needs to happen now is that I need to get a lot more heat, a lot faster into the boiler.
Initial research into getting more heat via the current burner reveals that this well made custom burner is performing at its best, so the gain in performance that I would like cannot come from this burner. That means I am now going to experiment with different burners and have been advised that this type of boiler works best with a blow torch burner. Now some of you may remember that this boat came with a brand new unused burner, that was not suitable, and to be honest, quite frightening!
My experiments are going to be with different types of blow torch burner with different gas jet sizes to get the best flame for this boiler. Since we are likely to be using a lot more gas, to combat the issues of gas pressure drop and tank freezing I will also have a look at using gas from the tank in liquid form and turning the liquid into gas using the heat of the burner. If you have experience of using gas blow torches in your model boats I would love to know the type of burner and gas nozzle size that you are using.
Here are photos of the lake yesterday and the original blow torch burner.
