Author Topic: Ship of the year 2017  (Read 4802 times)
Taranis
  • Balne Moor MBC
« on: November 23, 2020, 10:49:43 am »
Whilst browsing the net for suitable fire monitors to possibly scratch build I came across this Robert Allan design.
A designer recently mention a couple of times by Marco.
Very impressive spec
https://www.professionalmariner.com/2017-ship-of-the-year-protector/
ANDY
KitS
Re: Ship of the year 2017
« Reply #1 on: November 23, 2020, 06:27:24 pm »
Forty one THOUSAND gallons per minute water flow??????  %% %%
And I used to think that the 400 gpm servo-valves I worked with were big..................
Kit
marco
« Reply #2 on: November 23, 2020, 08:12:14 pm »
Bonjour
hello andy , here is a link where you have some informations about fire monitor .
https://workboatsandco.forumactif.com/t83-monitor-fifi-canon-a-eau
marco
« Reply #3 on: November 23, 2020, 08:56:57 pm »
One of the points I did not understand was.......
"one of the boat’s three eductors and a pair of hose manifolds glisten in the sun. There are four pumping systems on the boat — designated red, green, blue and white — with matching color-coded labels for the operators"
So I understand how eductor systems functions in the transfer of water in ships ballast systems, as in a similar manner to steam injectors function in water refilling of model steam engine boilers
Taranis
  • Balne Moor MBC
« Reply #4 on: November 23, 2020, 09:41:23 pm »
Bonjour
marco
Hi Marco, merci   :-)  . I found some very good ones in USA but postage is ridiculous. I do not need them to function.
So if you know of some at a fair price I am interested or I will make them.
Perfect but too costly shipped  https://www.harbormodels.com/har3520.html
ANDY
kinmel
« Reply #5 on: November 23, 2020, 10:44:08 pm »
So I understand how eductor systemsfunctions in the transfer of water in ships ballast systems, as in a similar manner to steam injectors function in water refilling of model steam engine boilers
Eductors and inductors are the same thing.
For firefighting,  high pressure water passes through a venturi nozzle and draws foam compound into the water stream and that passes through a second venturi which pulls in air. This generates an 8:1 foam which floats on most liquids to exclude air and thereby extinguishes the fire.
It is an impressive vessel, but it's firefighting technology dates back centuries, centrifugal pumps and venturi systems working together.
« Reply #6 on: November 24, 2020, 12:16:48 am »
Thanks kinmel....... now fully understood as for the venturi driven for mixed water+chemical retardants ........ Derek
