Author Topic: diva prop shaft  (Read 2559 times)
philgg1946
diva prop shaft
« on: November 26, 2020, 07:47:12 pm »
I've tried to reduce the noise from the prop shaft of this model,it's m2 bar quite flexible,I even put a new shaft in ,tried grease, any one had same prob can anyone give me any tips on how to make it quieter, phil g
Ralph
Re: diva prop shaft
« Reply #1 on: November 26, 2020, 09:59:52 pm »
Never had this problem but would fitting a PTFE sleeve the full length of the shaft tube help?  Bit like on a flexi shaft.
Ralph
radiojoe
Re: diva prop shaft
« Reply #2 on: November 26, 2020, 10:01:52 pm »
Hi Phil, Check if the shaft is straight by rolling it on a flat surface, if it is "true" noise is usually caused by out of line motor or worn universal joint.
Joe
mbm999
Re: diva prop shaft
« Reply #3 on: November 26, 2020, 10:18:21 pm »
When i built my Diva, the bearing at one end of the supplied prop had been attached at a slight angle so wouldn't even accept the shaft let alone turn. Maybe yours isn't as bad but is still slightly "off".
Klunk
Re: diva prop shaft
« Reply #4 on: November 27, 2020, 12:19:42 am »
a picture of inside would help. there are reasons for noise, so we might be able to see it.
Is the coupling aligned, propshaft supported, motor mount flexible etc etc
full time penguin
Tug Fanatic
Re: diva prop shaft
« Reply #5 on: November 27, 2020, 01:21:06 pm »
Prop damage/balance?
dodes
Re: diva prop shaft
« Reply #6 on: November 27, 2020, 02:55:43 pm »
I have had loud noise from models when the platform for the motor mounting has space between it and the hull. Really had bad noise on my smit neatherland model, I cured it by filling in the area under the bottom plywood shelf with P38.
philgg1946
Re: diva prop shaft
« Reply #7 on: November 29, 2020, 09:33:11 am »
Cheers,I've ordered a new prop shaft,  Phil
Page created in 0.236 seconds with 18 queries.
