Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13   Go Down
Author Topic: RV Nord Icelandia  (Read 90605 times)
cos918
Re: MV Nord Icelandia
« Reply #150 on: December 23, 2007, 05:47:34 pm »
so thats one main drive motor and one bow thruster. Rudder?
Ghost in the shell
« Reply #151 on: December 23, 2007, 05:50:10 pm »
no rudder.
bow thruster, vertical axis thruster, propeller
Go Nuclear!  you'll love it
cos918
« Reply #152 on: December 23, 2007, 05:56:36 pm »
ah i see they have taken a diffrent approach to all the other small sub manufactures. Most use 2 main drive motors set at an angle to drive the sub under and it turn like a tank ie on it motors
Ghost in the shell
« Reply #153 on: December 23, 2007, 05:59:09 pm »
their MINI SHARK i think is like that
cos918
« Reply #154 on: December 23, 2007, 06:09:24 pm »
OK What about in stead of trying to lift the sub at a given point why not try a cradle. It would make the whole lining up process a lot easier. As for the cable on the winch the only down side i can see to that is the cable could get caught in the subs pro nord pro on intangled on some thing making recovery difficult. All so how would a cable effect the subs handling
Ghost in the shell
« Reply #155 on: December 23, 2007, 06:13:28 pm »
I'll consider that :) see how it goes first
Ghost in the shell
« Reply #156 on: January 12, 2008, 06:43:31 pm »
new A-frame started, this one will be powered by a servo on the Port arm, with an idler servo on the starboard side.
at the top when complete will be the attatchment to get the submarine, two telescopic arms for rams on the sides.
Ghost in the shell
« Reply #157 on: January 25, 2008, 05:39:03 pm »
6705russell
« Reply #158 on: January 25, 2008, 05:49:10 pm »
Yes that looks good, quite a long travel considering its servo controlled.  O0
cos918
« Reply #159 on: January 25, 2008, 05:50:11 pm »
very nice and smooth . Can you lift a decent load on that frame
john
Ghost in the shell
« Reply #160 on: January 25, 2008, 05:51:13 pm »
for some reason, that servo gives me all the movement I need without the need for a servo stretcher.
as for lifting things, its only designed to lift mr lobster
« Reply #161 on: January 25, 2008, 05:51:45 pm »
Nice and smooth.
The long Build
« Reply #162 on: January 25, 2008, 05:51:53 pm »
Nice.
Is there no way you can get those servos lower into the hull..?
Ghost in the shell
« Reply #163 on: January 25, 2008, 05:54:23 pm »
thanks Martin.
Larry, I tried that at blackpool show and couldnt get the swing.  instead, I am going to build up the aft end into a super structure element, that will also help prevent red pelican syndrome
Ghost in the shell
« Reply #164 on: January 25, 2008, 05:59:09 pm »
over the top of the servo box there is to be a styrene lid, that will give access for wires etc around it it will have some railings if there is clearance between it and the sub cradle.  on the front of it, a couple of doors, at the top of it, some vents, probably a set of read mushrooms, and at the fan tail side of it, perhaps a small deck with a door to it, thus that servo box will become part of the ship.
« Reply #165 on: January 25, 2008, 07:17:27 pm »
Hi Ghost
You'll have to do a weight test and fit a SWL notice.      O0
Don't want you going under eh !!
Video looks good. If you want to lower the servos, maybe you could use a one to one pulley belt from Meccano ?, like a bicycle chain idea.
Cheers...Ken
Ghost in the shell
« Reply #166 on: January 25, 2008, 09:10:24 pm »
the reason they are positioned where they are kenny is to provide a break water at the stern of the hull, preventing pelican syndrome, :P
bigfella
« Reply #167 on: January 25, 2008, 10:15:32 pm »
Hi Mark
That really looks good, and to me, looks scale speed too. Have you been able to source a winch for the sub yet. Keep the pics and videos coming. I cant wait to see her on the water and in full action with the sub. I spent all yesterday trying to make 50calibre machine guns out of plastic card, do you know how small they are at 1/32 scale.
Regards David
Pointy
« Reply #168 on: January 25, 2008, 10:21:25 pm »
Love your crane! {-)
Ghost in the shell
« Reply #169 on: January 25, 2008, 10:23:34 pm »
he he he, thanks pointy,
need a winch for the sub, nah, even slicker idea, a grabber! two micro servos on the aft crane,
Ghost in the shell
« Reply #170 on: February 03, 2008, 04:19:52 pm »
The long Build
« Reply #171 on: February 03, 2008, 06:26:47 pm »
Nice.
The sub looks cool , where did you get it from ?
Ghost in the shell
« Reply #172 on: February 03, 2008, 06:27:39 pm »
cornwall model boats, £20 :D
Ghost in the shell
« Reply #173 on: February 03, 2008, 06:28:52 pm »
TLB next it is to install the frame's rams, box in the servos to weather guard them, and then to paint it all.
cos918
« Reply #174 on: February 03, 2008, 10:54:12 pm »
thats well smart but is that only posible on a dead calm day looked tricky to line up the sub.
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13   Go Up
