Author Topic: Help needed  (Read 1921 times)
terry1956
Help needed
« on: June 14, 2021, 05:47:56 pm »
Hi all out there. I need some help with this flat bottom ship. It needs a new keel, but I am not sure what size or weight to make it. The ship Is all wood 4 ft 6 long 8 inches wide, and as you can see a lot of sail. There was a keel at some time because there are two holes in the base of the hull to take the bolts. And a keel box inside the hull. But I have no idea how to judge the weigh needed to keep the ship upright. Hope someone can help. Thanks
terry1956
Re: Help needed
« Reply #1 on: June 14, 2021, 05:50:46 pm »
Picture of ship
Re: Help needed
« Reply #2 on: June 14, 2021, 09:42:00 pm »
Looks like a barge. The Thames Barge Trust may be able to help or know somebody who can.
Re: Help needed
« Reply #3 on: June 15, 2021, 01:53:13 am »
Thames Sailing Barges have a Facebook work Group...free to join, there are a number of models built.....ask as many questions as needed
https://www.facebook.com/groups/1491060737778004
The actual vessels do/did not have a single conventional keel, but used the twin side mounted retractable Lee Boards to assist in maintaining a righted attitude  %)  ....all rather complex to consider in a model I suspect
I am a Member, but unqualified to answer your questions
terry1956
Re: Help needed
« Reply #4 on: June 15, 2021, 07:55:19 am »
Thanks chaps
Big Ada
Re: Help needed
« Reply #5 on: June 15, 2021, 04:21:32 pm »
Try AMBO the Model Thames Barge group, my barge has three different weight Keels for different strength winds.
mickyrubble
Re: Help needed
« Reply #6 on: June 15, 2021, 06:49:52 pm »
Add ballast (lead) while its in the water,keep adding until its a the correct waterline,A fin made of ply approx 10'' ,Cast the lead in plaster of paris,Use a balsa plug to form the mold ,cast in 2 halves ,bolt together though the fin with epoxy resin.Hope this is of some help
