Author Topic: Getting revenge!  (Read 2983 times)
raflaunches
  • The Penguins are coming!!!
Getting revenge!
« on: August 07, 2021, 11:39:28 pm »
Some will remember a little while back I was ‘stabbed’ in the back by a C-130J Hercules which left a 6 inch gash across my back. Well on Friday morning in the early hours whilst most slept peacefully I had my revenge on the dastardly ZH866 by beating the hell out of the stowage bin door. Okay it was damaged by the Movers loading the aircraft and it was the loadmaster who found the door bent out of shape but it was my great pleasure to hit it back to relative shape with a large hammer and lumps of wood!
Nick B
Illegitimi non carborundum!
frogman3
Re: Getting revenge!
« Reply #1 on: August 08, 2021, 08:05:38 am »
WELL done Nick at least you got your revenge  on it in the end  :-))
but for me also i got my  revenge on a blommin great  black  insect <*< [size=0px]it was like a big black wasp about an inck long   that had stung me on my back of my left leg an its been hell all week [/size] >>:-( [size=0px]went to the docs an he gave me some  anti-bottics  to try an cure it as my leg all swelled up an it went all red an talk about painfull bleedin agony to walk an sitting down it throbbed terrible well last night the missus an i was watchin startrek [/size]
[size=0px]an out of nowhere this abomnation flew accross the livin room  an i treid to swat it but thankfully it flew into the door an i think it was stunned as it fell to the floor well i quickly despatched it to the bin an i thought right got you you begger take that AN NOW ITS WAR as ive noticed that the wasps an hornets seem bigger than usual as i had a big ashion hornet come into my model room an i was scared stiff an it was not the normal hornet as it was a brown an black stripes hornet an big about 2   to nr 3inches long but thank god it flew out of my window again but put the smoackers up me i blame clmate change as we seem to be getting bigger insects than we used to [/size]
[size=0px]chris[/size]
canabus
« Reply #2 on: August 08, 2021, 09:13:15 am »
Hi Frogman
WE had a wasp nest in an outside garden wall, so late one night with a full length of plastic 25mm pipe, a 90 degree bend, large funnel and a lump of rag.
Plus can can of petrol !!!
We pipe 5 liters of petrol into the nest and as they tried to come up the pipe, we put the rag over the funnel.
Next today we have no wasps !!!
The fumes kill them as they breathe via they skin.
Canabus
Tug Fanatic
« Reply #3 on: August 08, 2021, 09:33:23 am »
We had a set of patio doors at the end of the lounge which had an air brick underneath them. Wasps had somehow found their way through the brick and built a nest. There was an endless stream of wasps coming & going but never once did any come into the house even though the patio doors were open most of the time.
We started horrified & gradually became fascinated.
« Reply #4 on: August 08, 2021, 10:38:08 am »
For any wasp nest built around any surface of the home, spray the nest with standard WD40 [moisture inhibitor] .....wasps will either die or leave the area & rebuild the nest further away... O0
frogman3
« Reply #5 on: August 09, 2021, 08:36:50 am »
Hi Frogman
Canabus
HI Canabus well we cant afford to use petroll here in the uk as its like liquid gold an bloomin exspensive about i think nr £ 10 a gallon as i have to use super unleaded petroll in my car an how much is it a gallon where you are ?
chris
canabus
« Reply #6 on: August 09, 2021, 12:51:16 pm »
Hi
Unleaded petrol is $1.54 per liter in Tasmania!!!
Canabus
frogman3
« Reply #7 on: August 09, 2021, 01:22:19 pm »
Hi
Canabus
HI thanks for your reply an how much is that in english pounds ?
canabus
« Reply #8 on: August 09, 2021, 02:00:14 pm »
Hi Frogman
About .82 per liter, so 4.54 liters per gallon.
3.72 pounds!!!
Canabus
« Reply #9 on: August 09, 2021, 02:10:50 pm »
What!!!!!!!!!!!....0.82 per litre? :o ......in Tazzie?.
..all too complicated............... <*< >>:-( :} :} :} :} :} :} :}
« Reply #10 on: August 09, 2021, 02:17:39 pm »
KitS
« Reply #11 on: August 09, 2021, 02:22:45 pm »
Just FINDING Super Unleaded is a problem in these parts!  :((
Kit
frogman3
« Reply #12 on: August 09, 2021, 03:56:46 pm »
Hi Frogman
3.72 pounds!!!
Canabus
well Canabus you are getting it cheap here in uk 4.5 liters would set you back about  6 quid  or more
frogman3
« Reply #13 on: August 09, 2021, 04:10:43 pm »
HI YEA ITS goin to be all what we will have to use soon if i understand rightly as from the end of august they will be doin away with E5 UNLEADED AN BRINGING OUT AN E10 in its place an older classic car will have problems as they wont run on it so if your car is not at least a 2011 reg then the new unleaded will be no good for your car so they recommend super unleaded petroll which costs more per liter as thats what my car runs on so no worryies  as mine is a 13  year for me an there are three gargies around here what sells it so no prob for me  but if you have trouble finding super unleaded then you ought to start lookin for a garage that does sell it an i maybe wrong on this but i see this a couple of days ago on the web news
chris
« Reply #14 on: August 09, 2021, 10:59:46 pm »
I hope they don't go overboard on adding vegetable oil to our diesel as it will eat my pump seals. Land Rover products cannot take sunflower/vegetable oil like some can so you don't smell any 'Chip shop' Landys  {-)
frogman3
« Reply #15 on: August 10, 2021, 07:40:15 am »
HI YES thats what it said on this web news about it will damage rubber seals an pipes so if i was you id find out abit more before you stick any in if you do that is
JimG
« Reply #16 on: August 10, 2021, 12:44:08 pm »
chris
Plenty of videos on You Tube showing how to remove the alcohol from E10 or E5 petrol. Basically just add water to dissolve the alcohol then separate the two layers leaving the petrol. Of course you only have at most 90% of petrol left (water contaminated) and never mention how to dispose of the contaminated water safely at the end.
Jim
Dundee Model Boat club
Page created in 0.028 seconds with 17 queries.
