Author Topic: CQR (Plough) Anchor  (Read 4335 times)
ukmike
CQR (Plough) Anchor
« on: September 01, 2021, 11:24:39 pm »
Does anyone know where I might get a small example of the above, around 40 - 50mm  long would be ideal ?
Cap Maquettes have one but it's made of Resin and I would ideally like one of metal.
Mike.
Re: CQR (Plough) Anchor
« Reply #1 on: September 02, 2021, 12:50:38 am »
Mike.......Elde Modellbau have a comprehensive range of cast brass anchors and may be of interest
The names of anchor styles is very sketchy and vary between Countries and Centuries O0
I have their 55 x 44 mm 'Older style' [yet to be aged] anchor - this type has some 3 different names..Admirility, Porter Trotman and Vector  %) ]
Superb quality...they also do a range of studded [welded] anchor chain........[great people to deal with]
https://elde-modellbau.com/epages/bd40fd5d-0ba8-443f-857a-537621b491ae.sf/en_AU/?ObjectPath=/Shops/bd40fd5d-0ba8-443f-857a-537621b491ae/Categories/db2f40f24260bc41db48d82d5e7abf1d/b573ac82e38a329902e3bbd0a90953fb
Jerry C
« Reply #2 on: September 02, 2021, 11:11:12 am »
If it were me, I’d make one. A bit of brass sheet, a pair of snips and a bit of soldering. I made a Danforth anchor, only took me half an hour.
tonyH
« Reply #3 on: September 02, 2021, 11:59:06 am »
I've not use Battlecraft and I haven't checked all the sizes but this may suit. https://www.battlecrafts.com/component/j2store/products/plough-anchor-48mm
mrlownotes
« Reply #4 on: September 02, 2021, 01:56:16 pm »
https://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?WD=anchor%20plough&PN=CAP%2DMaquettes%2DPlough%2DAnchor%2D60mm%2DCMA83%2Ehtml#SID=727
Is this one any good ?
I always check Cornwall Model Boats for fittings.
They rarely dissapoint.
Bintur Ellenbach
« Reply #5 on: September 02, 2021, 02:01:29 pm »
Think thats the resin one mentioned in the original post.
mrlownotes
« Reply #6 on: September 02, 2021, 03:17:10 pm »
Oo Err Missus !
Apology tendered.
I must read more attentively !
Bintur Ellenbach
« Reply #7 on: September 02, 2021, 03:29:37 pm »
Jerry, your anchor is a Danforth - not a plough.
« Reply #8 on: September 02, 2021, 03:33:16 pm »
That's what Jerry said👍
« Reply #9 on: September 02, 2021, 04:31:18 pm »
My mistake, just looked at the pics! Sorry. However a Danforth is easy, a plough a bit more complicated to make.
« Reply #10 on: September 02, 2021, 04:52:25 pm »
I'm sure there was one made on one of the build blogs on here. Seem to recall it was plasticard though. May have been a lifeboat build.
mogurnda
« Reply #11 on: September 02, 2021, 07:46:39 pm »
Buy Five Oceans Plow/CQR Anchor, Stainless Steel AISI316, Weight 15.5 lb,  FO-344-FM Online in Japan. B08NCVJK91
Howard
« Reply #12 on: September 02, 2021, 07:51:18 pm »
It is Ned,
 done by a guy from Whitby. I have it some where
            Regards Howard
Howard
« Reply #13 on: September 02, 2021, 08:00:07 pm »
Hi Ned it was by a guy Called Dan Walker but just checked on its showing 404.
           Regards Howard.
tonyH
« Reply #14 on: September 02, 2021, 08:10:47 pm »
Has anyone here used battlecraft and if so are they any good 'cos at least this one's metal :-))
ukmike
« Reply #15 on: September 02, 2021, 10:10:50 pm »
Thanks for the info Derek,  certainly everything looks to be of very high quality.
Unfortunately they don't offer the CQR type.
Mike.
nemesis
« Reply #16 on: September 02, 2021, 10:22:20 pm »
If you are going to make one, use sheet Zinc as it replicates galvanising or stainless. They are easy to make. nemesis
ukmike
« Reply #17 on: September 02, 2021, 10:24:10 pm »
Looked at link to Battlecraft but no picture or information, also, they are Resin which I don't want.
I have decided to make one to the dimensions that I need in Brass, but, it will certainly take considerably longer than half an hour as the type is somewhat more complicated than the flat bladed Danforth.
Mike.
Jerry C
« Reply #18 on: September 03, 2021, 12:12:36 am »
Good on yer!  I’ve been stuck in Oz due to Covid. Things take ages to get here so I changed my mindset and made my own stuff  I only had brass, solder and paint. So far an anchor, navigation lights searchlight  and a circular wheel to lockdown a hatch. Necessity turned into fun.
Jerry C.
tonyH
« Reply #19 on: September 03, 2021, 09:12:40 am »
Mike.
You mean this metal one?  https://www.battlecrafts.com/deck-fittings/174-plough-anchor-48mm
I mean, just 'cos I'm in Suffolk %%
Tug Hercules Fireman
« Reply #20 on: September 03, 2021, 09:11:52 pm »
CAP Maquettes Fittings makes a nice CQR / Plough Anchor;
https://www.newcapmaquettes.com/Plough-Anchor.html?fromrec=1
Tug Hercules
Fireman Rick
“Ideals are like the Stars; We never reach them, but like
Mariners of the Sea, we chart our course by them.”
ukmike
« Reply #21 on: September 03, 2021, 11:05:26 pm »
Hi Tony.
Thanks for the new link but it's not quite the correct shape that I was looking for, although the dimensions are perfect.
Iv'e decided to make one, similar the the photo from Brass or possibly Aluminium.
Mike.
tonyH
« Reply #22 on: September 04, 2021, 11:50:19 am »
Hi Mike,
Definitely the best idea :-))
tghsmith
« Reply #23 on: September 04, 2021, 06:19:08 pm »
I would make one out of brass if I needed a metal one,, easy to solder, to get the correct finish the parts could be tinned with lead free plumbing solder, lots of drawings online.. just made one from plastic, brass would have taken just a little longer..
ukmike
« Reply #24 on: September 16, 2021, 02:59:25 pm »
Anchor complete, deliberately scruffy.
Second picture shows the finished one together with the first one that I started to make, didn't finish it due to it being too small but if anyone wants it let me know.
Mike.
Page created in 0.362 seconds with 18 queries.
