Author Topic: Best tools for cutting slots in plywood  (Read 3232 times)
dillinger 04
« on: December 11, 2021, 04:51:31 pm »
Hello Everyone
I am looking for the best tools for cutting roughly 4mm wide by 15 mm long rectangular slots in 4mm birch plywood for a prop shaft opening.
small hobby saws designed of cutting plywood? or other tools that might do the job . Any help would be appreciated
Footski
Re: Best tools for cutting slots in plywood
« Reply #1 on: December 11, 2021, 05:21:41 pm »
I would drill a hole in one corner and then use a small saw blade to make the cuts..filing down the edges once the hole is cut.
« Reply #2 on: December 11, 2021, 06:19:17 pm »
Urm have you got that right, a 4 mm slot in 4mm material.... :o
6705russell
« Reply #3 on: December 11, 2021, 06:23:53 pm »
I think he means 4mm thick plywood Phil not 4mm wide.. :embarrassed:
Mark T
« Reply #4 on: December 11, 2021, 06:48:28 pm »
Great advice  - this is what I would do
« Reply #5 on: December 11, 2021, 11:24:40 pm »
Considering this slot is for a prop shaft, the suggestion from Footski...of starting with 'a hole at either end makes absolute sense, as the entry/exit geometry of the shaft through the hull is an ellipse :-))
If the slot is 4mm wide, using a 4 diameter drill...and so if the slot is 15 long, have the slot drill centers @ ~~11 mm  ..... %)
[allows for feathering or tapering in/out]
Tug Fanatic
« Reply #6 on: December 12, 2021, 09:13:55 am »
4mm is a very narrow propshaft!
« Reply #7 on: December 12, 2021, 09:25:00 am »
4mm is normal for a shaft but the tube is usually 6mm or 8mm in diameter.
« Reply #8 on: December 12, 2021, 09:44:54 am »
The only times that I have used a prop shaft requiring a hole that small has involved plastic kit conversions and building my own prop shaft assembly, and they have always been a straight simple hole in a prepared spot.  If this is for anything other than a very small model (and 4mm ply says not), then it would normally want, as Colin says, a prop shaft assembly with a 6 or 8mm outside diameter tube.
Use a drill of the right diameter, drill in the centre of the shaft exit, when a hole is created, twist the rotating drill to elongated the hole with the splines of the spinning bit until you have one the right shape to accept the tube at the angle wanted.  The tube will need fixing in place, epoxy does that while at the same time sealing round the tube.
chas
« Reply #9 on: December 12, 2021, 12:23:14 pm »
I've just re read the original post, it says roughly 4 mm slots, presumably in sheet material. This, to me sounds like slots in frames to go over an installed prop shaft and tube.
  Whatever the slots are for, most people would use a hacksaw, with a fine toothed blade, then cut a little undersize, and file out for a good snug fit. Just like slots in bulkheads to go over a keel.
Charles
Tug Fanatic
« Reply #10 on: December 12, 2021, 03:24:04 pm »
Yes I was thinking of the whole propshaft assembly rather than just the shaft itself. Personally I would still want more than a 4mm hole for a 4mm shaft if at all possible.
Page created in 0.805 seconds with 17 queries.
