Pages: 1 2 3 [4]   Go Down
Author Topic: Aziz static to rc  (Read 15323 times)
ronnie42
Re: Aziz static to rc
« Reply #75 on: January 14, 2024, 11:02:54 am »
Winch started basic box and drum to check mechanism.https://m.youtube.com/shorts/NB4B3I4t8Yk
ronnie42
« Reply #76 on: January 14, 2024, 09:54:10 pm »
Sorting out the lights, found little strip lights 2 by 30mm smaller would be better for scale. Other side is micro LEDs with servo bushes cut to stop the light spreading upwards, the stop lights are fragile bust 2 snap easily. Need to work out size of cable for bow mast 3 or 4 little LEDs to fit.
« Reply #77 on: January 15, 2024, 12:14:20 am »
 Looking Good Ronnie!  👍
ronnie42
« Reply #78 on: January 26, 2024, 09:32:36 pm »
Have a slightly bent propshaft at the motor connection, only found out as I am going to go brushless. stripped out all the wiring as I found out that long battery leads to the ECU are a no- no so a rewire for much shorter cabling.Everything was up at the superstructure hatch and need to move back for short cable runs to the brushless gear.
ronnie42
« Reply #79 on: January 28, 2024, 10:50:32 am »
Posts to raise powe circuit board away from any water.
ronnie42
« Reply #80 on: January 28, 2024, 10:55:10 am »
Made an anchor out of scrap and winch mark 2 basic shape and the posts.
ronnie42
« Reply #81 on: January 28, 2024, 11:02:47 am »
ronnie42
« Reply #82 on: February 16, 2024, 03:53:31 pm »
Redone the stern roller, was sitting high. Filled in the recess at each end on hull below roller. Another fix was cutting away below roller to drain water out of the water trap.
Pages: 1 2 3 [4]   Go Up
Page created in 0.659 seconds with 18 queries.
