Author Topic: blown switch  (Read 1469 times)
Trucker
blown switch
« on: May 15, 2022, 05:09:52 pm »
hi all,
whilst on the lake today my life boat blew the main switch which is in line after the battery, whist under a good load, another fellow boater tested my system and said i have over 32 amps, as he tested just one side of the two motors, do i need a new switch in excess of 60amp, if so where on earth do i find one...
Trucker
Re: blown switch
« Reply #1 on: May 15, 2022, 06:41:16 pm »
I read somewhere .... switches have a 'switching load' (Inrush?!)  and a 'continuous current load',
( ... probably read it on here, that where I get all my useful information! )    :-))
In other words, you don't switch everything on at maximum current / load ( speed ).
Probably only need a 10A switching, 60A continuos....
https://en.wikipedia.org/wiki/Switch#Contact_terminology
https://cpc.farnell.com/w/c/electronic-electrical-components/switches-relays-solenoids/switches-accessories/toggle-switches/prl/results?sort=P_ATT_BASE_VALUE_1002223_EN_GB|1
JimG
Re: blown switch
« Reply #2 on: May 15, 2022, 08:33:07 pm »
You might be easier to a suitable relay to carry the current than a toggle switch. A small low current switch can then be used to energise the relay. Would a car starter solenoid switch work under continuous load as they have to switch high currents?
Jim
Dundee Model Boat club
