Author Topic: A2 Stainless vs Brass Fixings  (Read 2106 times)
bee.sting
  • Beginner, just bought my first boat.
« on: June 14, 2022, 11:23:15 pm »
Having deliberately bought a first boat which is in need of some work, I have a beginner question for you:
The fixings (nuts and bolts, etc) currently in use in the boat are almost exclusively brass. As I come to replace some of them and install new things, I can use either brass or stainless steel. What are the pros and cons of each of these? (My boat will frequently be run in salt water.)
Thanks in anticipation.
Re: A2 Stainless vs Brass Fixings
« Reply #1 on: June 15, 2022, 02:44:37 am »
Well Mr bee......it really depends on what you are aiming for  %)
If for scale appearance, Knupffer in Germany produce Model Sized bolts & nuts with smaller size hex
Standard M3 bolt & nut are manufactured from 5.37mm AF material
Model size M3 bolt & nut are manufactured from 3.95mm AF
Knupffer produce these model size in carbon steel, stainless & brass
Naturally your brass & stainless are both considered non corrosive
If you are heavy-handed  <*<  the steel/stainless steel have approximately twice the yield strength over brass
The typical electronics Stores sell the standard size [large hex] small bolts & nuts , I am sure there is a UK supplier for model sized materials, Knuppfer also sell direct to World wide ...[even OZ]
These are both M3 [standard size] hex head stainless to the left, them M3 [Model size] brass on the right
nemesis
« Reply #2 on: June 16, 2022, 07:27:51 pm »
if you run in salt water then stainless steel is the way to go, brass exudes a horrible green gunge is you have not got rid of every trace of salt water, been there, nemesis
« Reply #3 on: June 16, 2022, 07:42:30 pm »
Agree with Nemesis, brass really does not like salt water. Go stainless.
bee.sting
« Reply #4 on: June 16, 2022, 09:10:05 pm »
Thanks, folks, Stainless Steel it is then!
« Reply #5 on: June 17, 2022, 11:16:47 am »
The green gunge (Copper Sulphate) was a highly prized 'must have finish' for some interior "Designers" %)
