Author Topic: MFA Piranha Mk2  (Read 3517 times)
Biggles
MFA Piranha Mk2
« on: December 28, 2022, 02:06:56 pm »
Hi Guys
Managed to pick up a Mk2 MFA Piranha unstarted kit, looking for electric motor suggestions? I have a spare Absima 10T brushed motor - 36.500 rpm, 170 watt, 7.2- 7.4 volt, 540 size. Any other suggestions please, I want it fairly fast but not too stupid!
Thank You for your help.
Re: MFA Piranha Mk2
« Reply #1 on: December 28, 2022, 05:05:30 pm »
 That looks like a 'standard' sized 540 /550 motor.
 Try that motor first, as it's a 'standard' size, you can always swap it out after-the-fact.
Also, be prepared to try several different props, to find one that matches the motor properly...
  https://www.absima.shop/pp/absima-electric-motor-thrust-b-spec-10t.htm?shop=absima_en&SessionId=&a=article&ProdNr=2310071&t=19114&c=19131&p=19131
Subculture
    • Dive-in to Model submarines
Re: MFA Piranha Mk2
« Reply #2 on: December 28, 2022, 06:39:32 pm »
Go brushless. Better efficiency, no brushes to wear out, lighter etc.
Biggles
Re: MFA Piranha Mk2
« Reply #3 on: December 31, 2022, 03:34:03 pm »
Any idea what size brushless and voltage, running a 35mm prop?
Thank you
Subculture
Re: MFA Piranha Mk2
« Reply #4 on: December 31, 2022, 05:01:51 pm »
I would go for 3s (11.1v) minimum as that's kinder to the batteries. A 28mm or 35mm outrunner will be more than up to the job, and I would go for something rated around 1700-2500kv, which will give you a lively sport boat.
e.g. cheap as chips set-up, but these are pretty decent.
https://tinyurl.com/49e3ysyy
Biggles
Re: MFA Piranha Mk2
« Reply #5 on: January 01, 2023, 11:20:14 am »
Thank you for your help and advice, it’s greatly appreciated!
Happy New Year 2023 to you!
chas
Re: MFA Piranha Mk2
« Reply #6 on: January 01, 2023, 03:11:22 pm »
Can someone educate me. How normal is it to run good but old model designs with a prop speed of 25,000 plus revs? My fastest models are 12-15,000 revs and they seem very quick to me. I'm betting on me getting too old and out of date. <:(
Chas
Subculture
Re: MFA Piranha Mk2
« Reply #7 on: January 01, 2023, 09:03:53 pm »
Biggles
Re: MFA Piranha Mk2
« Reply #8 on: January 03, 2023, 01:18:00 pm »
Does anyone know if it’s possible to fit a KMB 28mm jetdrive to a Piranha?
Might be interesting!
Subculture
Re: MFA Piranha Mk2
« Reply #9 on: January 04, 2023, 11:52:08 am »
Sure, but a submerged drive works very well. Keep it simple.
Re: MFA Piranha Mk2
« Reply #10 on: January 04, 2023, 11:56:51 am »
Anyone know what the differences are between the original & the MkII ?
Fastelectrics
Re: MFA Piranha Mk2
« Reply #11 on: January 04, 2023, 08:40:27 pm »
Your 10 turn motor is a bit too hot for direct drive. Hook it up to a 3:1 gearbox to run it comfortably into a 30-35mm prop. The other option is to go brushless.
Fastelectrics
Re: MFA Piranha Mk2
« Reply #12 on: January 04, 2023, 09:07:38 pm »
Here is a video of a similar boat running on 3 LiPo cells rated at 2200mAh. The motor is a 1800KV 2212 brushless. The boat went well but the motor ran too hot despite being water cooled. I have since swapped it for a larger motor rated at 1350KV. I am now just waiting for the local boating pond to be refilled so that I can test it.   https://www.youtube.com/watch?v=Aqt-Pq3QHD4
Subculture
Re: MFA Piranha Mk2
« Reply #13 on: January 05, 2023, 02:22:19 pm »
What diameter and pitch of prop were you using with the 1800kv motor.
I tend to go for about 1.2x diameter pitch on my props.
Subculture
Re: MFA Piranha Mk2
« Reply #14 on: January 05, 2023, 09:19:56 pm »
Fastelectrics
Re: MFA Piranha Mk2
« Reply #15 on: January 07, 2023, 10:11:47 am »
I think the prop on the video boat was a 1.4 pitch 30mm diameter.
Page created in 1.214 seconds with 17 queries.
