Author Topic: Hello  (Read 2181 times)
SamM
Hello
« on: February 26, 2023, 08:28:44 pm »
Hello All,
Just recently retired and have had an interest in model boat building for some time but never got started so trawling the forum for ideas for my first build.
All the best
Sam
Tug Fanatic
Re: Hello
« Reply #1 on: February 26, 2023, 08:53:14 pm »
Welcome Sam.
This is a friendly group and I am sure that you will get help and advice if you ask for it.
Re: Hello
« Reply #2 on: February 26, 2023, 09:07:27 pm »
Welcome Sam
Tworrs
Re: Hello
« Reply #3 on: February 26, 2023, 09:39:30 pm »
Hi Sam and welcome  :-))
Re: Hello
« Reply #4 on: February 27, 2023, 09:54:30 am »
Welcome aboard Sam
Phil
jonggd
  • The Fleet!
Re: Hello
« Reply #5 on: February 27, 2023, 02:03:34 pm »
Welcome Sam, there are a lot of guys on the forum with so much knowledge, and always happy to help you as you start your model-making journey.
In the Dockyard...
1/128 HMS Warspite - QE Class Battleship
1/72 HMS Campbeltown - T22 Class Frigate
1/72 HMS Apollo - T12I Leander Class Frigate
1/72 HMS York - T42 Batch 3 Destroyer
On the Slipway...
1/72 HMS Duncan - T45 Destroyer
Geoff
Re: Hello
« Reply #6 on: February 27, 2023, 04:00:19 pm »
Hi, and welcome to the board. I think your first thoughts need to be how big do you want the model to be and if you have a particular interest such as warships, liners, fishing, speed boats etc.
Once decided I think its important to make something relatively simple to get you into the hobby. The main thing is enjoyment, for example I would counsel you perhaps not start with Titanic at 6 feet long as you may never finish it.
We are making models so in our world nothing is too critical in terms of engine size, prop size and the like and members on the board can easily provide guidance and counsel if you get stuck. We have all been there and got the t-shirt!
Geoff
Re: Hello
« Reply #7 on: February 27, 2023, 05:38:39 pm »
Geoff is spot on, one thing I used to do when I used to give a small presentation (on mainly steam....but still relevant) is ....how big is your car, and getting the boat to the water, a long walk with a heavy tug.....Grrrr.
My Uncle spent several years building a large version of the "Eileen" a fishing trawler, changed cars....and.....yes you guessed it, it would not go in..
Just a couple of thoughts  :-))
Tworrs
Re: Hello
« Reply #8 on: February 28, 2023, 08:38:07 am »
Hi Sam and welcome
Re: Hello
« Reply #9 on: February 28, 2023, 11:05:08 am »
Work on the KISS principle Sam. Have a look at the Glynn Guest designs or the E-Zee built site for a first model. Helps to get your feet wet and basic construction techniques. Vic Smeed designs are worth a look too.
Tug Fanatic
Re: Hello
« Reply #10 on: February 28, 2023, 11:46:02 am »
For a first build I agree that KISS is a great idea.
I would also suggest that wider relative to length makes building less critical (the model wants to stay the right way up even if hou have built heavy - which you most likely will).
You haven't given us any idea about what appeals to you. Pleasure boats, lifeboats, tugs, speed boats etc etc.
SamM
Re: Hello
« Reply #11 on: March 01, 2023, 11:09:57 am »
Thanks for all your friendly comments and advice much appreciated, my initial thoughts are tugs and trawlers.
Sam
Re: Hello
« Reply #12 on: March 01, 2023, 12:39:12 pm »
Hi Sam!
To get your hand in / practice building, many people have converted Dickie / Seaport tugs ....
 .... maybe worth a look!
https://www.modelboatmayhem.co.uk/forum/index.php/board,125.0.html
John W E
  • I see no ships !!
Re: Hello
« Reply #13 on: March 01, 2023, 03:53:56 pm »
hi there
Welcome to the Forum!   It depends on your skill levels - have you ever thought of building a model from a plan?  There are plenty free plans from magazines & etc., and the stable of Glynn Guest.  If you have a look in the master class build of this Forum - I myself have done several builds - they were specifically aimed at the beginner - & those with very limited experience.  It begins with a plan from our late friend Dave Milbourn - although it isn't a tug - it is a very straightforward motor speed boat.  It eases one in and I know there have been a good few of these built from this topic.    Don't forget to read the questions and answers on this forum - because there is a lot of information on here which comes from a variety of builders.
Then, if you look further down on the topic board - you will see there is a steam tug Cervia build - slightly more experience required.  Same again though, if you do run into difficulties there are plenty of helpers on this Forum.  The only thing I would change about this build - if I did it again - would be to have a direct drive motor, rather than a belt drive.
Third one, fishing trawler Spashett.   Then - you do need a little more experience for this.  I do know a few people have built this with very limited experience.
Couple of links follows :-)
THE FAIREY SWORDSMAN - A PLAN FOR BEGINNERS by Bluebird (modelboatmayhem.co.uk)
TUG CERVIA HULL BUILD by Bluebird (modelboatmayhem.co.uk)
PLAN BUILD NUMBER 4: DRIFTER/TRAWLER FREDERICK SPASHETT (modelboatmayhem.co.uk)
Knowledge begins with respect
destroyer42
Re: Hello
« Reply #14 on: March 01, 2023, 05:29:19 pm »
Hi Sam
There are a few kit manufactures they may interest you, start with something easy to gain expirence and knowlege then gradually work your way up.
Suggested kits links attached [size=78%]Boat Kits – Hughes Aircraft Kits (hakits.co.uk)[/size]    [size=78%]SLEC UK Ltd[/size][size=78%]        Have alook at the attached.        [/size]
[size=78%]Regards[/size]
[size=78%]Destroyer42[/size]
cuk.com
Tug Fanatic
Re: Hello
« Reply #15 on: March 01, 2023, 06:31:34 pm »
Hello again,
Delighted to hear that you are into tugs (see my sign in picture). I am no expert on fishing boats but the same rules will apply. They are generally stocky and stable which makes for a very usable model.
Where to start. These are my thoughts. Others will have different ideas. Be honest with yourself. Do you have a fully equipped workshop & are you expert in using it? How much time can you devote to the build? When do you want a near complete model? What is your budget?
You need to decide whether you want freelance, a plan or a kit. Don't underestimate the time that any of these will take. A complex tug built from a plan, or even some kits, can take years to complete. Given this I would suggest something simpler. My first tug was a fibreglass hull which I still think was the best idea. It meant that I had a watertight motorised hull quite quickly. Seeing your ballasted hull motor round the pound is a real boost. The superstructure and detail can then be added over as long a time as you wish.
Size wise I would suggest somewhere around 24-36in. This is a size that allows easy access and installation without being vastly expensive nor impossible to transport.
The exception to all the above is something like a Springer. 18in and as simple or complicated as you like with a simple hull that easily accommodates everything that you want to put into it. Thousands built and enjoyed.
See here:
https://www.modelboatmayhem.co.uk/forum/index.php/board,95.0.html
and especially here:
https://www.rcgroups.com/forums/showthread.php?522762-Springer-Class-R-c-Boats
you can look through all the images here:
https://www.rcgroups.com/forums/thumbgallery.php?t=522762&do=threadgallery
Page created in 0.167 seconds with 18 queries.
