Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Contenairship Maersk CONAKRY  (Read 41982 times)
PierreP
Re: Contenairship Maersk CONAKRY
« Reply #75 on: May 13, 2024, 07:43:32 pm »
the last photos
PierreP
« Reply #76 on: May 24, 2024, 07:35:13 pm »
cylinder mechanics
PierreP
« Reply #77 on: June 02, 2024, 05:06:00 pm »
I redid the structure of a crane in 2MM Plexi. The cylinder movement motor is a 6v 500tr/min
PierreP
« Reply #78 on: June 02, 2024, 05:07:12 pm »
Crane rotation system
PierreP
« Reply #79 on: June 02, 2024, 05:08:17 pm »
Winch of the crane
« Reply #80 on: June 02, 2024, 10:55:20 pm »
Nice modelling / engineering Pierre !   :-))
PierreP
« Reply #81 on: June 13, 2024, 06:21:02 am »
Installation of the crane control system
PierreP
« Reply #82 on: August 02, 2024, 02:50:44 pm »
Hello, I have started the construction of 1200 containers. I made all 6 sides. The measurements of a 40 foot container are L12.2cm l2.4cm h2, 9cm or 2.6cm. I have built several container models. Afterwards I built compartments. I filled my molds with blue liquid silicone. After 10 molds of each shape I filled them with epoxy resin.
PierreP
« Reply #83 on: August 02, 2024, 03:04:19 pm »
Here is my molding company and the result of the molds I am very satisfied with the result
PierreP
« Reply #84 on: August 05, 2024, 08:23:46 pm »
Hello,
here are some pictures of my brand new containers that I've molded and assembled myself. When you look for containers on the internet, you can only find 1/87 scale containers but mine are 1/100.
PierreP
« Reply #85 on: August 05, 2024, 08:28:11 pm »
I am currently looking for a way to add transfer printing on my container. Does any of you have an idea on how to do this ? I would like to "create" the Maersk, Hamburg Sud, CMACGM, MCO, P&O, Safmarine logos.
KitS
« Reply #86 on: August 05, 2024, 10:38:24 pm »
Aren't container decals available for those company names?
I know they are in more usual scales, such as HO & N Gauge railway scales, but some suppliers also do them in other, more varied scales too.
Kit
« Reply #87 on: August 05, 2024, 11:47:23 pm »
This is how I did mine Pierre
https://www.modelboatmayhem.co.uk/forum/index.php/topic,59223.25.html
...reply no.39 and 46 on page 2 of that blog :-))
Cheers,
Ray
steve mahoney
« Reply #88 on: August 06, 2024, 10:03:33 am »
I've had custom water-slide decals made in the past from Bedlam Creations in the US. I'm sure there is someone similar closer to you.
They can print just about any colour, including white.
You can gang up quite a few logos on an A4 sheet, although those ridges could be a problem. How many containers will need logos? Not all 1200.
PierreP
« Reply #89 on: August 08, 2024, 04:49:15 pm »
Thanks for that information, knowing that, i will try to find something .
PierreP
« Reply #90 on: August 08, 2024, 04:51:35 pm »
Cheers,
Ray
Thank you ! Ihave seen your work and i will try to use your tip.
PierreP
« Reply #91 on: August 08, 2024, 04:57:38 pm »
Thanks for your answer ! 158 of my containers will have logos (5 different ones) i will try to find that on the internet.
PierreP
« Reply #92 on: August 10, 2024, 05:33:37 pm »
Start of painting for the parts of my containers. This represent only one set of fourteen modules.
KitS
« Reply #93 on: August 11, 2024, 04:00:36 pm »
Wouldn't it be easier to paint them once they're assembled? As it is you'll have to scrape the paint off the joints before you glue them together surely?
Kit
PierreP
« Reply #94 on: September 17, 2024, 05:54:20 pm »
Painting of module parts 1, 2, 3 and 4
PierreP
« Reply #95 on: September 17, 2024, 05:56:18 pm »
Assembly of the first module
PierreP
« Reply #96 on: October 19, 2024, 05:34:09 pm »
The construction of the containers is progressing well. There are about 1000 contenairs on the deck
PierreP
« Reply #97 on: October 19, 2024, 05:35:25 pm »
Some photos
PierreP
« Reply #98 on: October 19, 2024, 05:37:02 pm »
other photos
PierreP
« Reply #99 on: October 19, 2024, 05:37:52 pm »
One last
Pages: 1 2 3 [4] 5 6 7   Go Up
Page created in 0.02 seconds with 18 queries.
