Pages: 1 2 [3]   Go Down
Author Topic: Uj joints for brushless motors  (Read 10385 times)
Geoff
Re: Uj joints for brushless motors
« Reply #50 on: October 10, 2023, 11:59:50 am »
I take your point re axial loads with brushless motors when used in model planes, good point. Are the same motors used in boats, I just don't know but a valid point indeed. However the couplings may not take these axial loads which is the main point.
Geoff
Subculture
    • Dive-in to Model submarines
« Reply #51 on: October 10, 2023, 02:34:36 pm »
That would depend on the coupling. A solid coupling will clearly transmit the load. A cardan style coupling would also transfer axial force. A dog and bone coupling would not transmit an axial load, as the two parts are not connected axially.
ooyah/2
« Reply #52 on: October 21, 2023, 01:09:25 pm »
Hi GUY'S,
A bit late on this subject but here is how I make DOG & BONE couplings.
Get a flat used file about 1" wide by 3/16" thk stick about 12" into a coal fire and leave it there until cool in the morning.
Cut off about 5" of the file with hack saw
Drill and form a a hole as shown in pic to suit the size of the ball, hole to be . 015'" dia smaller than the finished ball to allow filing to final dia, make sure that the cut is 7deg to allow swarf clearance.
When completed re harden the tool for cutting the ball.
The driver to the engine is a simple turning job and the final ball has a 1/16" dia rod drilled thro'.
When finished case harden the mild steel components.
All done quite easily
George.
« Reply #53 on: October 21, 2023, 01:21:18 pm »
An oldie but goody  ;)  Miles better than the plastic monstrosities
 Regards   Ian.
John W E
  • I see no ships !!
« Reply #54 on: October 21, 2023, 01:34:20 pm »
George, definitely one of the best solutions - the only problem I can see now is - do people know what a coal fire is these days.  There probably wont be many around now - by God I would give an arm and a leg to have a coal fire in this house that I live in now - the modern thing with no chimney.
Well, rant over.
Knowledge begins with respect
ooyah/2
« Reply #55 on: October 21, 2023, 03:17:25 pm »
WHAT ,
No Chimly what about Santa
Geo
philk
« Reply #56 on: October 21, 2023, 03:20:59 pm »
WHAT ,
Geo
haven't you heard santa's not woke enough
« Reply #57 on: October 26, 2023, 03:04:27 pm »
   This is what we need! ...
ooyah/2
« Reply #58 on: October 27, 2023, 11:41:12 am »
Wow,  That's what I call a coupling.
George
Pages: 1 2 [3]   Go Up
