Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: Gasoline powered Tugboat  (Read 118347 times)
1967Brutus
Re: Gasoline powered Tugboat
« Reply #150 on: July 03, 2025, 10:26:50 am »
Engine is out, and this situation:
has to somehow change into something like this:
I did some off the cuff calculations, which suggest that in the direct drive situation, the prop demanded about 1 Nm of torque to maintain 1500 RPM, at the pitch setting the engine would still pull at that RPM. Just as an indication: that is about the torque a 10 kg servo pulls.
Although intuitively one might think, that a reduction gear increases torque, this is not the case, it is the load that DETERMINES torque. The prop now spinning 3,7 times slower, means that the prop demands a lot less torque.
Meanwhile, firing up the trusty old Electric Jigsaw, because I have some carpentry to do, in order to install that gearbox.
1967Brutus
« Reply #151 on: July 03, 2025, 02:42:06 pm »
The rusty old electric jigsaw still functions well, so about 1,5 hrs (most of it "curing time") later, I basically ended up with this:
To my eye (I have a very vivid imagination, did I allready tell you guys?) it starts to look more and more like a true marine Diesel...
The boltholes are slotted to allow for alignment, and the bracket is built to be plane-parallel with the flywheel. That should make it possible to align the gearbox parallel and concentric with the crankshaft. to within a sufficient small margin.
One or two hours more to allow the aliphatic to thoroughly cure, I will slap on two coats of pore filler, and then two more coats of polyurethane parquet lacquer for oil and waterproofing.
The blocked portside cooling tube turned out to get unblocked very easily so now that we have ample cooling capacity, it also is time to install a controlled cooling bypass, which can be done in the meantime the coating of the gearbox-bracket is curing.
The way this is going, I expect to be able to do a bathtub-testrun tomorrow evening, which opens up tyhe possibility to take part in a Demo on Saturday.
1967Brutus
« Reply #152 on: July 03, 2025, 07:22:41 pm »
I know this pic is a near duplicate of one posted earlier, but it really is not.
The gearbox in its final installation.
The construction is strong enough to turn over the engine acting on the gearbox output shaft (against a 3,7:1 increasing gear ratio, takes considerable force) so I am more than positive that this will hold, and alignment seems to be quite OK.
Also did a quick 'n dirty bypass control valve for temperature regulation, no pics yet, will be posted later.
1967Brutus
« Reply #153 on: July 04, 2025, 10:28:00 am »
https://www.youtube.com/watch?v=eZqfwz1ecFU
Not the prettiest video I've ever made, but I'm absolutely very satisfied...
Unfortunately I can't measure any bollard pull in the bathtub, but the first impression suggests that I've made considerable concessions in that area, but judging by the propwash the speed is still OK.
The engine runs a bit rougher and more irregular due to the lower torque load and especially the reduced inertia in the driveline, but this could also be a carburetion issue, because the engine is now running in a completely different load range.
I was a bit afraid of a lot of gear whine, but that's not too bad.
But then the advantages: WOW! I have "pitch control" like I've never experienced before with this boat. Stop is stop, and everything reacts immediately to small changes, whether forward, backward, or "a little more or less".
I've set everything up so that in forward position at 65% stick, the pitch is at full tilt. From 50% onwards, throttle is added as well.
The first part of the stick deflection is therefore purely pitch at more or less constant speed, the second part is mainly "speed controlled".
Where previously with the propeller in neutral position there was a lot of turbulence in the water, this has now almost disappeared. I think the "prop walk" has now also almost disappeared (previously Woutertje was turning on the spot at a fairly fast pace when stopped).
The temperature control also works brilliantly, responds well to the settings, only those settings are a bit "coarse".
In the bathtub test I saw the temperature go up and down by 2 degrees at most, where it was striking to see that when I gave full throttle, due to the higher speed (and therefore higher pump speed) the temperature first dropped by 1 degree.
When adjusting the control point, a reaction was visible within a few seconds, but the smallest step is soon 4 or 5 degrees.
I now have a temperature of between 74 and 76 degrees, one step higher and we soon see 80 degrees, one step lower and the whole thing goes to 70 degrees plus minus.
I have been running without a superstructure for a while, I see no strange vibrations or oscillations in the driveline, I think this is going well.
What I unfortunately did NOT see was oil circulation in the gearbox, but it could be that there was a bit too little oil in it.
I am happy, and this afternoon I will go to the club pond to test on open water, and then we will also do a bollard pull test.
JimG
« Reply #154 on: July 04, 2025, 12:34:19 pm »
Really good work there, I don't know if you use Facebook or not. If you are on Facebook there is a group Model Engines - Old and New whose members would be really interested in seeing your work. It is a private group so you need to join it before seeing anything. Engines include I.C and steam.
Jim
Dundee Model Boat club
1967Brutus
« Reply #155 on: July 04, 2025, 03:06:33 pm »
Jim
Hi Jim,
I have too many groups and pages to attend to as it is allready, but you have my full permission to link to this thread, as well as the "gasoline Alexandra" thread in the sports&pleasureboats section, or the "Pimped Microcosm" in the steam section, in that facebook group.
Bert
1967Brutus
« Reply #156 on: July 04, 2025, 03:18:43 pm »
Well...
For a very first time sailing, not bad at all... Not perfect, I noticed that the completely different load and torque range in which the engine is now running has quite an effect on the carburetor settings. And since the fuel consumption has also visibly decreased (I think I have now sailed for a good hour with 150 ml, that was around 200 ml before) things are now EVEN more critical than they already were...
The engine stalled quite often on the water this session, and that is not nice of course, but that on-board starter is fantastic. I guess, with some finetuning, that will slowly get better.
What I expected turned out to be true: I have lost a lot of pulling power, but I do not know exactly how much yet, because my unster jumps on hold after a few seconds, and I spend too much time letting the boat rest fall into the wire. I really need some help with that. But from what I could see, it dropped from 1,9 kilo in the direct drive version, to about 1, maybe 1,1 kilo in this set-up.
I made a "towing resistance", just an almost filled (so still just floating) jerrycan.
That actually went quite well... Towing and filming at the same time is quite difficult, so just a short vid:
https://www.youtube.com/watch?v=KO_pu-FzcXs
Of course, the improved functioning of the propeller pitch control was also filmed, and this is also a cinematographic disaster of a film, but anyway:
https://www.youtube.com/watch?v=n34LlAlYJj0
The swift and unambiguous response of the boat is a HUGE improvement, propwalk indeed is virtually completely gone when the boat is stopped in the water, and this makes handling the boat when there is a towing line out behind it, a LOT easier and safer.
At the end of the ride, the drive belt of the water pump snapped (lucky, because I can see THAT on the telemetry, I still have to figure something out for the lub oil pump), so to be on the safe side, I replaced both.
This set has been on, if I remember correctly, since just before the engine was tinkered with in Woutertje, the hour counter is now at 6 hours, so I think I'll replace them every 2 hours to be on the safe side. Then I still have stock for at least 70 hours of operation.
I think the gearbox reaches about 60 degrees, about "hot to the fingertips, but no pull-back reflex".
« Reply #157 on: July 04, 2025, 04:18:19 pm »
    So I fired up the trusty old Ferm piece of crap masquerading as a lathe
« Reply #158 on: July 04, 2025, 04:32:18 pm »
  Not sure if you've already posted Brutus... how is the exhaust routed?
1967Brutus
« Reply #159 on: July 04, 2025, 06:13:09 pm »
I think I posted that, but can't remember for sure.
In any case, I routed the exhaust through the actual funnel. For that, I took off the funnel from the accomodation, worked out the innards so I could fit an aluminium tube all the way up.
At the engine manifold, I hooked up an old expansion muffler from a .12 class IC RC car model, which "more or less" fitted relatively conveniently.
The muffler is connected to the funnel-tube by about 20 cm (8") thin walled very flexible Silicone tubing.
It is a bit of a fuss to pop that tubing on the muffler, but once done, it usually does not have to come off again for a while.
So when the boat is sailing, it emits a nice blue plume of exhaust gas from the authentic place.
https://www.youtube.com/watch?v=_6-f_VWYC54
It is remarkable how positive people respond to that: "Oh, look, it even has smoke coming out"... Most people do not realize that that is not just smoke but actual exhaust gas from an actual engine... Funny, that...
1967Brutus
« Reply #160 on: July 05, 2025, 09:24:10 pm »
Me and my smug self...
Tested the boat yesterday because of a meeting today.
No problems yesterday, but today went through 6 or 7 water pump drive belts, none lasted longer than 2 or 3 minutes, but no apparent reason for the faillure.
Finally the last run, the pump turned out to be stuck, so I was of course pretty "xxxxx".
Initially feared pump bearings were shot, but it turned out I obviously failed to clean out all the metal debris from modifying the cooling system.
Had to open the pump to remove a few splinters, and flush out the entire system.
Tested the boat in the bathtub for 15 minutes, seems OK.
1967Brutus
« Reply #161 on: July 06, 2025, 09:15:28 am »
Oops... Apparently I used language that was off limits.
My sincere apologies to the users and mods, I really was not out to offend anyone.
1967Brutus
« Reply #162 on: July 06, 2025, 07:19:35 pm »
Since I hurt my back yesterday putting the boat in the water, I did not feel going back to the RC meeting today.
So I did a little maintenance (refreshed oil, regreased prop, adjusted valve clearances, nothing too fancy) and cleaned the "engine room" a bit.
Sump oil probably has been in the engine for about 5 runhours, and was black, but did not look "dirty" if you get what I mean. Pretty sure, the new charge can hold maybe 10 hours.
Put the boat through its paces one more time, for 30 minutes, most of it at full power, with occasional manouvering, mainly to fine tune the temperature control.
Since I now have variable RPM (and thus coolant flowrate rising and falling with RPM) this "following flowrate" apparently greatly assists in keeping water temperature constant. I draw that conclusion because I most definitely see controlling action of the bypass valve, and the temperature very positively follows the setpoint if I change that in the TX programming, but there is very little action based on "load": If the RPM goes up, the controlvalve more or less remains in the same position, and the temperature by and large remains constant. Which makes sense, I guess, since a higher flowrate at the same temperature also results in a greater heat transfer, apparently keeping pace with the also increased heat production.
The funny thing is: if the engine has stabilized at idle/prop neutral, and then full ahead is ordered, due to the immediate rise in flowrate, while the engine block is not yet "heat saturated", the temperature initially DROPS a bit, and vice versa, when the engine has stabilized at full ahead, and neutral is ordered, the heat-saturated block and now reduced flow cause the temperature to rise, ever so slightly.
I got that on (rather boring) video.
https://www.youtube.com/watch?v=HkTEqgTl8Bk
Also, due to the control system, the engine heats up much quicker, previously it took about 4~5 minutes for the temperature to stabilize (not very stable, I usually saw about 5~10 degrees C variation, depending on load and speed through water), but now it stabilizes in about 1~1,5 minute, and variation is 1, maybe 2 degrees.
I still want to try and install an oil temperature sensor, because of how I connected the coolant-bypass to end between oil cooler and liner-cooling.
After the moral dip of yesterday, now pretty happy about how the installation is functioning.
1967Brutus
« Reply #163 on: July 08, 2025, 09:40:02 pm »
Where last weekend (Saturday) was a total off day, today was the local club-evening, and Woutertje functioned flawless, for a full two runs of each approx 50 minutes, with a bunkerstop inbetween. The fuel tank was nowhere near empty at the first stop, but better safe than sorry. I think the tank allows about 90 minutes of runtime.
EDIT: Checking the "bunkerstation" it turns out I went through approx 250 ml of "bunkers"...
Bought myself a cheap inflatable dhingy, and duh, what do you think....
https://www.youtube.com/watch?v=VW7p_9WWX_8
1967Brutus
« Reply #164 on: July 10, 2025, 08:19:16 pm »
And a next step has been made:
A long time ago I made a "kinda-sorta" oil cooler for the Cison, basically the reasoning was "if it helps none, it also won't hurt none".
I still had a free temperature telemetry port, so a few minutes fidgetting with the sensor, a piece of brass tubing and opening the oil line after the pump, and presto, an oil temperature measurement.
Of course, this needed to be tested, because I wanted to know what kind of oil temperature we are running, and of course I also wanted to know if this oil cooler thingy actually does anything... (yup, ANY excuse to play in the bathtub... :p).
Tested for little bit over 15 minutes. Water temperature rose pretty quickly, in about 2 minutes that was above 70 deg C and stabilizing.
Oil temperature came up a LOT slower, took about 10 minutes to stabilize, and it ended around 56~57 deg C.
Now the interesting thing was that oil temperature followed load, but SLOWLY... At full ahead it crept to 57, at zero pitch, it VERY slowly dropped to 56. I repeated this 2 or 3 times to make sure, and it was repeatable.
The latter means that the oil cooler is ACTUALLY functioning, because the topside of the engine never dropped below 75 degrees, and that drop in temperature needs to come from somewhere.
55~60 degrees is a mighty fine temperature, loads of headroom, the oils I am using can easily handle 100 deg C or higher, but below 60 is very nice.
Only thing is, it is not hot enough for the oil to evaporate water or fuel, so it means regular oil changes to get rid of accumulated pollutants. But that is no biggie, it's only 25 ml per charge.
I'm a happy chappy again...
1967Brutus
« Reply #165 on: July 13, 2025, 07:17:51 pm »
And today another clubmeet (different club, different pond), so also another near 2 hrs of runtime (counter now at 10 hr 50 min, meaning the gearbox and temperature control now both have about 5 hrs of operational time).
This time 2 x 15 minutes of "people transport" (towing myself around the pond), and I did not see the engine above 75 (short hiccups of 76) and oil temperature never went above 58 deg C. With free running boat, those temperatures were even a bit lower.
I am absolutely happy... My towing skills also improved, I managed to tow without a single jerk in the towline. Takes quite a bit of focus and pretty quick thinking, but I managed. Could also be beginners luck...
1967Brutus
« Reply #166 on: July 14, 2025, 11:57:48 am »
The newer design looks to be more secure. I probabbly bought the Rivabo vp prop around 40 years ago to replace the reversing gear setup I had originally made for the tug. This worked ok but with straight cut steel gears it was noisy and gave a loud clunk every time iit changed from forwards to reverse or back, there was also no proper neutral position so the boat couldn't be stopped.
Jim
Just as an aside note, I recently, actually just yesterday, learned that "Rivabo" actually WAS Raboesch, one of their trading names (probably a different derivate of the name of the company founder). Which made me think about your description of having the pitch yoke screwed on the shaft... I can only think of the need for a shaft/hub design suitable for both directions of rotation as a reason why they would change that design.
1967Brutus
« Reply #167 on: August 05, 2025, 10:23:01 pm »
Changed the towing gear from a single line to a towline with bridle, and that basically completely transformed the handling from tricky and demanding full attention to a lot less critical and much easier to control.
Where with the single line the tow was swerving continuously and hard to control precisely, with the bridle it is very easy to keep that swerving in check.
When coming around in the lock where we usually run the boats, with the single line a lot of attention was needed to prevent jerks in the line due to the tow swaying uncontrollably when the tension was off the wire, but now I can turn around by reducing speed slightly before the turn, holding a light pull, initiating the turn then go full throttle, keeping the towline at a 45 degree angle to the tug. The lean angle of the tug can be controlled beautifully with small rudder corrections and remains uncritical, and the continuous force in the line creates a nice "slingshot effect" when straightening out at the end of the turn. No jerks, no scary moments like before, very cool manouvre to perform.
Other than that, the engine starts easy first start of the evening, keeps starting reliably and quickly, does not stop or stall unless commanded to stop, runs like a champ...
I put 80 minutes on the clock this evening, for a very consistent fuel consuption of 250 ml. No measurable oil consuption.
This whole thing worked out better than I ever dared hoping.
1967Brutus
« Reply #168 on: August 07, 2025, 07:28:59 pm »
Making a start with restoring the cosmetics of the boat:
The railing of the starboard bridgewing is still "reasonably intact" but portside was missing the webbings and was one stanchion short to begin with, and aside from that, the construction was very fragile with 2 mm toprail and 1 mm webbing, all connections glued.
This is the first time EVER that I made something like this, and I had the extra difficulty of having it fit the existing holes in the superstructure. So I am not unhappy with it.
Made the stanchions and toprail out of 2,5 mm, and the webbings in 1,5 mm, looks just that bit better to size. Drilled the stanchions, and soldered all connections:
I had to do the soldering "in situ" because the finished item, soldered and all cannot be positioned in the holes, those holes being in all different angles. So I had to use tin and an iron, could not use a flame and silver. The lumps of solder however, look bigger in the pic, than they are in reality
EDIT: oops... the handrail for the stairs still was on the workbench...
Remaining glueing and bondo-ing the holes, and painting, and then... Oh dang, repeat this for starboard...
1967Brutus
« Reply #169 on: August 08, 2025, 05:03:56 pm »
Since I did not want the new railing to look like a crown on a cowpie, I did not spend too much effort in the finishing.
Soldered a hook for a lifebuoy, slapped some paint on, filled out the broken-away patches in the woodwork of the superstructure, and called it a day for this one.
The "new" matches the style and finish quality of the rest of the boat, so it doesn't stick out like a sore thumb.
1967Brutus
« Reply #170 on: August 09, 2025, 09:16:22 pm »
And finally.... FINALLY, "Woutertje" proudly wears her new name...
My granddaughter was a bit dissapointed, when she found out that her mother (my daughter) and her granny (my wife) had a boat named after them, but she didn't...
Back then I did not even have a 3rd boat, but I could see in that little angle face that that was not a good enough explanation...
So promises made, promises kept.
1967Brutus
« Reply #171 on: August 10, 2025, 08:51:50 pm »
Strictly for the technically interested:
Today was one of those days that an oil change was due (I try to do that approx every 5 runhours, and I think this filling had slightly over  that).
Out of curiousity, I did a paper-chromatography (one drop of the liquid to be tested, in this case the sump oil, on a piece of filter paper, left to dry in an oven at 75 deg C), a crude method to determine pollution or stability of that liquid.
I used to do this test to keep track of the break in of my aero-engines, with some interpretation skills it is a fairly usable method to monitor the break in progress in those aero engines.
As an example, the tests of my radial after its first, 5th and 10th bench run.
The dark center is the dirt/break-in debris, carbon, soot etc, the clean corona around it is the oil.
In real life, sometimes with the naked eye, sometimes you need a magnifying glass, metal particles can be seen.
The sump oil, after 14 hours of runtime on the engine, 5 hours on the oil, tested like this:
Zero visible particles, not even a hint of glitter, and no center spot. An ever so slight and narrow corona suggests two liquids, which CAN indicate that a tiny bit of the 2-stroke oil in the fuel seeps past the pistonrings but does not really mix with the automotive lube oil in the sump.
In any case, this seems to indicate the engine is absolutely in excellent mechanical condition. I am pretty happy with that.
1967Brutus
« Reply #172 on: August 12, 2025, 08:02:05 am »
Ain't kids cute when playing with their toys? :D
1967Brutus
« Reply #173 on: September 01, 2025, 09:15:01 am »
1967Brutus
« Reply #174 on: September 07, 2025, 07:07:24 pm »
Last week, doing a demo in some public park pond, apparently sometimes people are fishing over there as well, as at the end of the day it turned out I picked up a bit of fishing wire.
So, cutting away that curled up Nylon string, I thought that was that, although there is a rather deep partition between the propshaft tunnel and the prop hub.
In that partition a ballbearing runs more or less open, so pulling fishing wire in that partition IS somewhat of a risk. If the wire tangles with the cage and rollers of that bearing, no good can come from that...
After pulling out the wire, and then regreasing the hub, nothing unusual. It wasn't too much wire, maybe one metre in total, and in one piece as far as I could tell.
Yesterday was another demo day, this time in a "portable basin", which at least means, NO fishing wire...
So I was a bit amazed to see first the water being squeezed out of the hub during regreasing, behave differently. Normally it comes out a bit like squeezing a sponge: all around and in large slow drops, but this time it came out at only one spot, with some force and velocity, and in a fine jet.
When after a few squeezes, grease exited all around, I was a bit surprised to see another piece of wire sticking out, which I carefully pulled out with a tweezer. It was maybe 10 or 15 cm.
But where there is one, there can be more. so I straightened out an old nail trimming scissors, and started poking.
30 minutes or so later:
(fingertip for scale)
Using the phone camera as a magnifying glass, a few more strands were visible.
All in all, in 30+ mins I removed at least 1 to 1,5 metres of wire, all in short broken strands. Nasty job, and that wire getting entangled in the rolling elements of the ball bearing might damage it or at least cause accelerated wear.
Replacing that bearing, it IS possible, but a nightmare of a job...
So I think I will in the near future fabricate a protective cover over that partition, preventing wire getting in there.
Wire in the prop is inconvenient but not a danger to the prop, but wire getting in that partition.... >:-o
Oh, forgot to mention: Alesha's runhour counter currently is 17,5 hrs, which more or less means there is approx 3,5 litres of fuel through, and it has all appearance that oil consumption has dropped to "undetectable" (last three outings, I did not see any drop in oil level when checked with the boat at the same spot on the workbench, yes, the dipstick is indexed). Also, I think the drive belts for the pumps are now in place at least 8 hours or so, and the oil is in about 5 hr.
I'll leave the oil given the last filterpaper chromatography, but I think I will change the belts just to be on the safe side.
Pages: 1 2 3 4 5 6 [7] 8   Go Up
