Author Topic: Identifying an old Tomahawk Products sound module. (wiring?)  (Read 2791 times)
AndyR
« on: April 03, 2024, 03:46:13 pm »
Does anyone have any information bout this unit?
It is from an old Mount Fleet Ben Ain that I have been given and needs a rebuild.
I don't know what the terminals are for, which is power? which is speaker@ etc.
It seems the manufacturer no longer exists.
DocMartin
Re: Identifying an old Tomahawk Products sound module. (wiring?)
« Reply #1 on: April 03, 2024, 04:25:31 pm »
Do you have a better picture of the full circuit board???  It may help answer some of your questions.
AndyR
« Reply #2 on: April 03, 2024, 05:41:03 pm »
The orange connector on the right is power, it's marked with a + and -
The black one has diodes connected in opposite polarity on it, I think they may be for the 'pulse breaker' that goes to the motor.
That would leave the white ones as speaker.
AndyR
« Reply #3 on: April 03, 2024, 06:56:43 pm »
Apparently Componentshop.co.uk took over the products.
I will email and see if they have any circuit diagram or instructions.
DocMartin
« Reply #4 on: April 03, 2024, 09:46:33 pm »
With the information you've provided, I'm guessing the set-up and control of your module could be related to this:
https://www.componentshop.co.uk/p56-steam-engine-sound-simulator.html.html
Check out the PDF file, as the controls and connections you describe are similar.
Hope this helps!
AndyR
« Reply #5 on: April 03, 2024, 10:40:12 pm »
Yes, I was just looking at that, it's got fewer components than the one I have and the two pots for volume and state are in different locations, but it looks like it could be a development of the original Tomahawk.
This one has a bunch of 'potted' components under a metal cover that seems to be acting as a heat sink for a hefty transistor, that screw you can see is holding the transistor against the cover I wonder if it's got a built in amp.
Mrs Stav
« Reply #6 on: April 05, 2024, 03:10:46 pm »
not at all anything to do with ACTion electronics Dave Milbourn devised his own systems as he was ACTion.
Stan Reffin can you help at all
Mrs Stav
Where's the cake ??? I only joined for the cake !!
Stan
« Reply #7 on: April 05, 2024, 04:58:33 pm »
Sadly not.
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #8 on: April 05, 2024, 06:49:12 pm »
What about these photos DocMartin asked for? They'll reveal if its an audio amp or a timer circuit regardless of whether chip numbers are scratched off.
Its more likely to be some sort of smoke unit controller. Tomahawk search turns up smoke unit, Ben Ain has a lum, and a smoke unit would also have a motor connection by diode bridge.
AndyR
« Reply #9 on: April 05, 2024, 07:30:21 pm »
Haven't had chance to take any yet, I will do them this evening.
AndyR
« Reply #10 on: April 06, 2024, 11:56:19 pm »
I suppose 'Steam Chuffer' could apply to a smoke unit or a sound unit.
DocMartin
« Reply #11 on: April 07, 2024, 12:31:05 am »
Earlier comments deleted as upon closer review, the circuit board clearly has printed "TRAIN CHUFFER" at the edge.
+1 comments previously left by HMS Invisible
AndyR
« Reply #12 on: April 07, 2024, 10:08:36 am »
Further on a motor connector via diode bridge, there's what looks like a diode bridge by the black connectors, four diodes.
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #13 on: April 07, 2024, 11:00:45 am »
I didn't notice the words "train chuffer" before. That's surely a sound unit. There would be no harm in connecting a high impedance speaker or headphones, say 64 ohm, or lower with a series resistor.
Maybe a search on web.archive.org shows something.
DocMartin
« Reply #14 on: April 07, 2024, 01:35:13 pm »
Curiosity killed the cat, but satisfaction brought it back.  %)
Following HMS Invisible's suggestion, I searched web.archive.org and found a few archived pages.
Attached is a product list and available wav. files for the associated sound cards.  Interestingly, TP offered both a smoke generator and a steam sound generator.
AndyR
« Reply #15 on: April 07, 2024, 06:39:36 pm »
Good find.
Unfortunately there's no part number on the unit  :((
DocMartin
« Reply #16 on: April 07, 2024, 06:49:36 pm »
Perhaps the "motor" output is really the connection point for the associated (add-on) smoke generator.
AndyR
« Reply #17 on: April 07, 2024, 09:28:26 pm »
There's a small black box with it labelled 'Pulse Breaker'
I just noticed that in small lettering next to a pair of captive wires it says "Connect to sound generator"
At the other end is a pair of terminals with "connect to motor)track" and separately "Polarity not important"
AndyR
« Reply #18 on: April 08, 2024, 12:07:25 pm »
A new development.
In among all the bits that came with the Ben Ain kit is a scrap of paper I ignored up to now.
It has written on it
"Two medium wires to sound unit (9 volts)"
I guess that answers the question about what it is.
I also noticed that the two white terminals are screwed down tight shut whereas the two black and the orange marked with + and - are unscrewed.
As there isn't a speaker anywhere in the boat or the bits I am guessing they were never unscrewed to fit any wires.
That, I think answers all my questions about what goes where and what exactly the thing is.
Thanks to those that responded.
