Author Topic: steam engine  (Read 2496 times)
pipercub1772
steam engine
« on: April 19, 2024, 07:24:57 pm »
Hi what is the best solution for freeing a steam engine that has been left a long time without cleaning and lightly oiling, I have used turps previously can you suggest anything better ,kind regards
rhavrane
  • Steam passionate collector
Re: steam engine
« Reply #1 on: April 19, 2024, 08:35:55 pm »
Bonjour,
Would a large cleaning inside and outside with WD40 or equivalent would be useful ?
But before, if the machine does not run, remove the cylinder heads to look for any possible traces of rust or other dirt possibly blocking.
In all the cases, never force !
This is a common disease for cast iron made machines.
Raphaël
1967Brutus
Re: steam engine
« Reply #2 on: April 19, 2024, 08:58:22 pm »
Andyn
Re: steam engine
« Reply #3 on: April 19, 2024, 10:37:17 pm »
If you have some, a bath in glow fuel will clear it right up
pipercub1772
Re: steam engine
« Reply #4 on: April 20, 2024, 09:03:06 am »
Thanks for the information i have some glow fuel ill give it a try thanks for the replies ,regards Allan
Bunkerbarge
Re: steam engine
« Reply #5 on: April 20, 2024, 12:20:42 pm »
If the engine has been left so long it is tight you really should do the right thing and strip it down.  You need to check the condition of the bores and whatever is sealing the piston and piston rods, i.e. 'O' rings or soft packing.  Simply soaking it and forcing it to turn runs the risk of damaging the seals and the running faces that could be scored.  You might even think you've got away with it as it frees up but you might have done damage that won't be immediately apparent.
Strip it down and clean everything up properly.
Re: steam engine
« Reply #6 on: April 20, 2024, 12:25:44 pm »
Hydraulic oil. Thinner than 'Penetrating oil'
Re: steam engine
« Reply #7 on: April 20, 2024, 01:19:56 pm »
As AndyN as said glow fuel does work....but after freeing uo the engine it should be stripped and cleaned (petrol works) as glow fuel is very corrosive
1967Brutus
Re: steam engine
« Reply #8 on: April 20, 2024, 06:14:28 pm »
I strongly doubt that... Penetrating oils are waterthin, most Hydraulic oils I worked with had Viscosity classes of 32 or 46 (cSt)...
pipercub1772
Re: steam engine
« Reply #9 on: April 22, 2024, 05:42:00 pm »
Thanks for all the replies the glow fuel did the trick thanks  , i would normally strip it down as Bunkerbarge recommended but its a martin howes and baylis pb2 engine and honestly think it would be a bridge too far for me , so thanks again for all the information ,regards Allan
1967Brutus
Re: steam engine
« Reply #10 on: April 22, 2024, 07:31:23 pm »
If you're not going to strip it, initially do NOT run it, but give it ample of any kind of lubricating and cleaning liquid while "slowly" turning over, and that way rinse out the engine to get rid of any corrosion particles. Glow fuel would be a good medium for that.
