Author Topic: 686 tug  (Read 4701 times)
Klunk
686 tug
« on: May 15, 2024, 07:07:26 am »
Having recently purchased, then resprayed it, I now need extra batteries.  Any idea what the connector is?
full time penguin
Andyn
Re: 686 tug
« Reply #1 on: May 15, 2024, 07:28:32 am »
Klunk
Re: 686 tug
« Reply #2 on: May 15, 2024, 10:01:29 am »
Cheers upgrading battery!!!
full time penguin
Re: 686 tug
« Reply #3 on: May 15, 2024, 02:44:34 pm »
....NB.  There two types of connectors with these tugs a black one and smaller white one.
Andyn
Re: 686 tug
« Reply #4 on: May 15, 2024, 05:03:12 pm »
The Heng Long one comes with the smaller connector on the battery, but it’s also double the price so can’t see that many people buying it
Klunk
Re: 686 tug
« Reply #5 on: May 15, 2024, 07:28:36 pm »
Mine has the smaller white plug. £15 Inc postage!
full time penguin
Re: 686 tug
« Reply #6 on: May 15, 2024, 07:51:44 pm »
Nearly as much as the tug....
Tug Fanatic
Re: 686 tug
« Reply #7 on: May 15, 2024, 08:17:55 pm »
Mine has the black plug. £12.28 delivered!  :-))
I am working out what to cut away in the deck so that I can get at water etc in the bottom of the hull. I am thinking of cutting out the battery box and altering the top motor bracket so that the battery can go between the motors. I am inclined to leave the plastic under the wheelhouse as it also helps locate the wheelhouse and keep it on the boat.
Has anybody put a seal between the hull & the deck?
Re: 686 tug
« Reply #9 on: May 16, 2024, 10:34:56 am »
Beyond the realms of possibility to change the connectors for cheaper versions?  %)
Klunk
Re: 686 tug
« Reply #10 on: May 17, 2024, 12:14:02 am »
Look underneath near the kortz nozzle, there is a rubber bung
full time penguin
Tug Fanatic
Re: 686 tug
« Reply #11 on: May 17, 2024, 10:13:24 am »
Yes there is bit if you look inside the hull you will find that it is a small raised area within the hull which mean that it won't work at all well as a drain point.
You really do need access to a "mopping" location.
