This is for reference only, Neil, so don't panic.
As I mentioned earlier on in my last post - I had sent for one of the Chinese twin speed controllers as mentioned by HMS Invisible.
I sent a message to the seller on Ebay, saying that I hadn't received the one in the pictures - strangely enough he asked me for photographs of the one I received, so I have done that. Some of these are the pics that I sent back.
The last one is to show you the ease of set up with the wires. The only thing that may confuse people is plugging the single yellow signal wire from the ESC into the white signal side of a Y lead. The male plug side of this Y lead is then plugged into your receiver, leaving the other female side of the Y lead to plug into your rudder servo.
I have done a bit rooting around about obtaining some better information on this particular speed controller; and, it does look as though it has a built in thermal. So, if it is overloaded on either motor it will shut down until the fault is rectified.
Last but not least, and this is throwing the cat amongst the pigeons Neil; if you look at the old Electronize speed controllers; the ones that used to come with the built in fuse holders -which side of the speed controller was the fuse fitted? On the battery side.
