Author Topic: Boat Supports  (Read 1748 times)
Barney Magrew
Boat Supports
« on: September 30, 2024, 12:15:42 pm »
HelloI am after some scale acrow props, the kind you see fitted to a trailer for supporting a boat in transit.  Can't seem to find anythinng, even an stl file to print some.Any ideas.Thank you
Geoff
Re: Boat Supports
« Reply #1 on: January 30, 2025, 04:25:43 pm »
As a suggestion if you get some long screws (M4) which are a sliding fit into brass tube you can readily make your own. Superglue one screw in at one end with some thread showing then do the same at the other end. You can easily make some wedges in plastic.
Geoff
ChrisF
  • What's my favourite cake!
Re: Boat Supports
« Reply #2 on: January 30, 2025, 09:37:21 pm »
Don't know what length you want and the longer ones start getting expensive but ShipWrightShop  have some turnbuckles that might do the job.
Chris
Re: Boat Supports
« Reply #3 on: January 31, 2025, 10:21:30 am »
Wash your mouth out with soapy water Geoff, "Make from scratch?????????????"   What a ridiculous idea.  %)
 Regards  Ian
ChrisF
Re: Boat Supports
« Reply #4 on: January 31, 2025, 10:28:05 am »
Page created in 0.027 seconds with 17 queries.
