Author Topic: One I made earlier  (Read 2787 times)
Sonar
One I made earlier
« on: October 24, 2024, 11:02:36 am »
Not been about on the forum for some time now. Been bust with a million other things .
But now just started again
I am not the best in fact far from it and most of my creations look well knackered when I finish them. But it’s the enjoyment I get out of it .
Anyway a long time ago I was messing about with plywood ect and decided to make a hull and a mould.
Inspired by this site…
The plywood hull went in the bin  I  think it did but I have still got the hull moulding.
So got it out today dusted it off.
Made a few minor repairs as it has been kicking about wherever it was put and ended up behind the back of the shed
Polished it and now thinking I may well make one and see what I have got ..
As I said it’s been some time .
So far it’s 46 inches long
12 1/2 inches wide and 10 inches deep approx.
It’s quite exciting as I am not sure what I will get.
Re: One I made earlier
« Reply #1 on: October 24, 2024, 02:58:24 pm »
That, for a "first" mould, i presume from what you say is an absolute cracker.
Been making grp moulds fopr at least 45 years, and that is lookijg superb......your hull should with proper preperation to the mould before moulding should come out as sweet as a nut.
Good lucj and take it slowly but carefully on the moulding and you can look forward to a perfect casting.  :-))
« Reply #2 on: October 24, 2024, 03:01:02 pm »
it  looks as though it could be a fishing vessel
Sonar
« Reply #3 on: October 24, 2024, 03:19:24 pm »
I did start it a long time ago as a fishing vessel with a sloping transom then thought it could even be a tug. Or any vessel that needs to recover anything via the stern.
I have still not decided .
It has an indentation where the bow thrusters could go if required and also a void for the anchors .
Provision for a twin Props or korts.  I guess it’s not a kit so it can be anything.
However I will wait till I have pulled out a moulding next week or so..
« Reply #4 on: October 24, 2024, 08:04:45 pm »
Looking forward to.....well whatever it will be...... :-))
« Reply #5 on: October 24, 2024, 08:05:23 pm »
look forward to seeing it pop out...........just love the soumd when it "cracks" and it pops out.
Sonar
« Reply #6 on: October 24, 2024, 08:55:07 pm »
I will gel and lay it up tomorrow  then pull it when I get more time after the week end
Sonar
« Reply #7 on: October 25, 2024, 09:07:20 am »
Gel coated and laid up early this morning   So will turn it out of its split mould soon and update the thread…
>IMG-0685
Now thinking I may make a shorter one. Two options. Here either cut and destroy the mould
Or make a false fitting transom  and see what I get then …
but two would be more than enough for a while .
But with carefully made transoms the sizes that can be made would amount to different looking hulls.
And of course with a moulding  made double the thickness this opens up a new option on cutting up the new hull moulding and  making something else to make a mould of.
As I made the mould myself not using another hull  I made it out of plywood and plastic there is no copyright.
And as far as I know it’s not the same size of any other hulls I have seen .
So endless options.
Sonar
« Reply #8 on: October 25, 2024, 11:53:57 am »
Split mould
I had a bit of mould damage to repair due to a metal something hitting the inside..
Sonar
« Reply #9 on: October 25, 2024, 12:02:30 pm »
Just found the link to when I started the mould
https://www.modelboatmayhem.co.uk/forum/index.php/topic,69395.0.html
And here is the result. Not polished washed cleaned or trimmed just right out of the mould
Extra layer of 600 gram matting to top all round. The bow thruster openings the prop shaft areas and the rudder areas
"IMG-0689[/
IMG-0691
IMG-0692
IMG-0693
IMG-0694
IMG-0695
Update when I have it cleaned up including more accurate sizes
Needs a good polish with some g3 liquid.
Sonar
« Reply #10 on: October 25, 2024, 02:01:34 pm »
Now trimmed  just mould joints to clean off and then a tidy .
IMG-0696
IMG-0697
« Reply #11 on: October 25, 2024, 07:51:12 pm »
very nice, lovely hull. :-))
« Reply #12 on: November 05, 2024, 09:12:21 pm »
SO!!! WHATS HAPPENED TO ALL THE PHOTOS??? :(( %)
Big Ada
« Reply #13 on: November 06, 2024, 04:05:05 pm »
Postimage has stopped showing them,  I cant see them either.
Len.
« Reply #14 on: November 06, 2024, 05:05:24 pm »
  >>:-(   PostImage...  but they usually come back after short while ... usually!
 Try https://www.modelboatmayhemimages.co.uk/upload - https://imgbb.com/  - https://imgbox.com/
See: https://www.modelboatmayhem.co.uk/forum/index.php/topic,61103.0.html
Sonar
« Reply #15 on: November 07, 2024, 07:44:56 am »
I don’t know they seem to have vanished  altogether from the post image site.
I may have to repost the lot again
And here are a few of a stubby version
[size=78%]IMG-0712[/size]
IMG-0713
I am now thinking one more moulding a little bigger and that’s enough then.
Sonar
« Reply #16 on: November 09, 2024, 06:26:54 pm »
Here are some of the missing images from the first post
Thinking one more from the mould ….. med sized on ….
Sonar
« Reply #17 on: November 12, 2024, 05:38:37 pm »
Just cut the stubby hull up. I may have to reduce the bow a little .
I am sure this could make something interesting . May be an anchor handling vessel.
Or something like an oil rig support vessel. Who knows as I don’t know myself yet 😂😂😂
But if I have cut it too low I will have to make another .
