Author Topic: Two or Four ESC’s USS Missouri  (Read 1277 times)
XS850
« on: February 05, 2025, 11:07:55 am »
A query for all the electronic wizards please. Currently building a Trumpeter USS Missouri (1:200) with 4 driven props - am I better driving each “pair” (port & starboard) of motors from a single ESC or individual ESC per motor (brushed 280/5’s)?
Keeping in mind there is likely to be a small difference in loading as the two inner props are 5 bladed and 2 outers are 4 bladed. All ESC will be controlled by a mixer which adds to the wiring complexity but no problems for me.
My query relates to whether there could be a problem with current draw as the inner motors “may” draw more than the outers so the “balance” between each pair won’t be the same - what effect could that have or am I worrying too much about not a lot?!
Cheers - Bruce
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
Re: Two or Four ESC’s USS Missouri
« Reply #1 on: February 05, 2025, 11:49:41 am »
Tasked to do this for anyone, I would do it with a single 16 amp dual mixing esc.
Specifically, the smaller brother of this one. https://www.aliexpress.com/item/1005005376657723.html
You have not specified an operating voltage.
Stan
« Reply #2 on: February 05, 2025, 06:39:49 pm »
HI Bruce this is my Missouri two ESC fitted works fine.
XS850
« Reply #3 on: February 05, 2025, 06:53:03 pm »
Hi Stan - many thanks for the photos and confirmation, puts my mind at ease (not to mention my wallet!).
Is that Yamato next to Missouri as that’s my next build once Big Mo is completed, if so that shows me the way to go with the motors etc (even more room to play with!!).
Bruce
Stan
« Reply #4 on: February 05, 2025, 08:26:22 pm »
Hi Bruce the rear of my Yamato.
