Author Topic: Smit Rotterdam motors  (Read 6672 times)
Nick-R
« on: April 23, 2025, 11:12:33 am »
Just ordered the Billing Smit Rotterdam kit.  It is twin screw with largish props.  I am not sure on what motors/battery to go for but looking at a pair of MFA 950D geared motors.  Should I go for 2.5:1. or 6:1 gear ratio?  Also I would usually go for a 2s or 3s lipo but would a 12v lead acid battery be better in this application?
Re: Smit Rotterdam motors
« Reply #1 on: April 24, 2025, 09:42:43 pm »
Gears motors can be quite noisy ...... just sayin' !
https://www.mfacomodrills.com/pdfs/950D-series.pdf
« Reply #2 on: April 25, 2025, 09:07:24 am »
If using 12 volts 555 motors direct drive will be fine.
Nick-R
« Reply #3 on: April 25, 2025, 04:02:19 pm »
Cheers gents.  Abandoning the geared idea and just go for direct drive.  Will look for high torque low speed brushed motors.
Nick-R
« Reply #4 on: May 01, 2025, 12:23:09 am »
Just a wee follow up.  Ordered a pair of Mabuchi 555 high torque motors and clearly Billings designed the model around this size.  The fit into the motor mount cut outs in the frames straight out of the kit is perfect and alignment with the shafts is pretty much spot on.  I previously built a Billings Nordkap and was impressed with that kit but the Smit Rotterdam so far, is on a different level.
Page created in 0.089 seconds with 17 queries.
