Author Topic: Wide Awake - Build Moulds  (Read 8772 times)
CliveJ
« on: May 12, 2025, 08:31:21 am »
Hopefully someone can help me, please
I read a very detailed Wide Awake build - the builder stated there was a problem with the moulds that had to be addressed, unfortunately, the builder could not recall the 'problem'
I am now at the stage where I am about to start planking but reluctant to start until I have confidence in the moulds
Clive
CliveJ
Re: Wide Awake - Build Moulds
« Reply #2 on: May 12, 2025, 09:38:31 am »
Hi Martin,
Thank you for your response
It was Patternmaker that make the comment in his build log which alerted me to the potential problem with the moulds
CliveJ
« Reply #3 on: July 19, 2025, 07:04:18 am »
An update
Having now virtually finished the planking
With 4 planks to go it was apparent that the planks were not going to form the correct shear line at completion  :((
This is my first venture into clinker construction and I have learnt a lot from it  :-))
Firstly it is difficult and very time consuming to produce the individual planks and secondly do not rely on the moulds alone to provide the correct plank spacing !
Before commencing the build I did research construction but did not 'strike' a shear line through the moulds before then dividing each mould by 12 equal spaces - this was a mistake - I believed and relied on the moulds being the correct depth as per those on the drawings and divided them each by 12
With 4 planks to go I was able to address this and form a correct Shear line, however, I now do not have 'equal' plank spacing (particularly at mould 2) - this is very disappointing as I have invested many many hours in this construction and I wish I had struck the shear line from the outset and not relied on the moulds alone for spacing
This may go unnoticed by many - but unfortunately not me  >:-o  there are still many hours left to complete the build !
As I say I have learnt a lot, would I build another clinker ? jury is out on that one :-)
Hopefully this may help someone setting out to build clinker - research does not trump experience as I have found out !
Page created in 0.355 seconds with 18 queries.
