Author Topic: Action Electronics P94 Dual Esc mixer and controller.  (Read 8412 times)
Lister
« on: May 12, 2025, 11:37:48 am »
Hi Guys,
Not been on the Site for quite a while due to various reasons including a cancer diagnosis.
My question is, has anyone used the P94 in any of their models and experienced problems?
I would be interested to hear about them. I am having problems with the installation of mine in my Al Khubar 2 harbour tug.
Kind regards,
Lister (Ian)
Re: Action Electronics P94 Dual Esc mixer and controller.
« Reply #1 on: May 12, 2025, 01:39:03 pm »
What radio set are you using and what are the problems?
Lister
« Reply #2 on: May 12, 2025, 02:27:07 pm »
I am using a Futaba T6EX transmitter and an FR Sky TFR6 receiver.
Setup as Tank Steering.
Rudder and starboard motor ok but can’t get the port motor to work.
If I connect the port motor to the starboard out let from the P94 it works ok.
« Reply #3 on: May 13, 2025, 10:11:32 am »
I would contacy component shop as that set up should be OK.
Lister
« Reply #4 on: May 13, 2025, 05:15:56 pm »
Hi Bob,
Thanks for that information I will contact Component Shop.
Kind Regards, Ian
John W E
  • I see no ships !!
« Reply #5 on: May 13, 2025, 05:56:27 pm »
hi there
Is your P94 a modern mixer or an older mixer as from Dave Milbourn's days?
Does it work in mode 2, 3 and 4?  as it should do?
Also, last but not least, do you have the connections set up correctly as in H1 on the mixer itself and H2?   Do these connections correspond with your output on your receivers? because, on some transmitters the throttle stick on your transmitter which is normally in mode 2 on the left is (on some receivers) instead of being channel 3 it is sometimes channel 1 or channel 4.
Knowledge begins with respect
