Author Topic: Canopy  (Read 3366 times)
Rob47
Canopy
« on: April 01, 2026, 02:14:22 pm »
As many know building an aircraft carrier can be dictated by available scale of aircraft. My QE has air win printed in 1/96 but as 3d printed they have solid caopies, so question any suggestions paint solid to make it look like a clear canopy?
I will finish this model
KitS
Re: Canopy
« Reply #1 on: April 01, 2026, 03:12:03 pm »
In 1/96 scale painting them gloss black with a few pale blue squiggles can work quite well. Almost by definition the aircraft will be some distance from viewers when the ship's afloat anyway.
Kit
Rob47
Re: Canopy
« Reply #2 on: April 01, 2026, 04:29:00 pm »
Kits
Yep have done that and found a coat of mask ol? helps as well. As you say hard to tell once on the water and this build though big is fun not exhibition level
Re: Canopy
« Reply #3 on: April 01, 2026, 04:31:24 pm »
Just a thought for the future.
You can 3d print clear plastic. If you printed the canopies seperately in clear, and printed the fuselage with the canopy area cut out, in a solid. Then glue together.
T888
Re: Canopy
« Reply #4 on: April 01, 2026, 04:33:35 pm »
Hi Rob, :-))
This is my method I use, for helicopters Aluminium mixed with a bit of black, aircraft I use Aluminium mixed with white.
Regards David
South Coast Modellers
Rob47
Re: Canopy
« Reply #5 on: April 01, 2026, 05:09:06 pm »
Easy if you?re doing the printing and what you say makes sense, but these are commercial items
Rob47
Re: Canopy
« Reply #6 on: April 01, 2026, 05:10:52 pm »
Hi Rob, :-))
Dave any particular manufacturer for the aluminium paint, will give it whirl
T888
Re: Canopy
« Reply #7 on: April 01, 2026, 05:14:13 pm »
Rob,
TAMIYA paint
Regards David
douglas g
Re: Canopy
« Reply #8 on: April 01, 2026, 05:54:01 pm »
A very soft pencil, e.g. 5B or 6B, can give quite a good effect, with a small amount of shine.
Rob47
Re: Canopy
« Reply #9 on: April 01, 2026, 05:55:43 pm »
Rob,
TAMIYA paint
Last one Dave :o  Matt, gloss or satin?
T888
Re: Canopy
« Reply #10 on: April 01, 2026, 06:19:06 pm »
Rob,
Aluminium flat
Black gloss
White gloss
This I find gives a satan effect. If you are looking for a shinny effect I?ve use I the past on cockpit instrument panel which is a clear coating which I also use for keep clear cockpit canopy?s clear.
it Dries perfectly clear, And Gives a glass like appearance. Just have to be careful not to shake the Jar and create a bubbly froth
Regards David
Page created in 0.013 seconds with 16 queries.
