Author Topic: Rudder Linkage?  (Read 3806 times)
Billyruffian
Rudder Linkage?
« on: November 19, 2007, 02:04:40 pm »
As a first timer with R/C boats, I am slowly getting to grips with averything but need to ask about the steering linkage.
The Caldercraft kit I have of the SS Talacre has a white-metal arm that sits ontop of the rudder post.  I gues this is then somehow linked to a similar arm on the servo - correct?
My question is where can I get relacement steering arms as I would like to get better then white-metal and are ther commercially available parts for making the seering linkage and if so where from.
Any advice would be very much appreciated
Re: Rudder Linkage
« Reply #1 on: November 19, 2007, 02:33:59 pm »
I have used the pins recovered fron dead 13amp plugs for quite some time.  Just a bit of work with a small drill and a big file, and you have a nice brass arm with a brass screw.  Sailing in salt water like I do, this is a valid consideration, a steel tends to rust solid on the way down to the pond.
Most model shops stock plastic arms with a brass bush and a grub screw.
John W E
  • I see no ships !!
Re: Rudder Linkage?
« Reply #2 on: November 19, 2007, 02:49:02 pm »
Hi there Billyruffian
If you have a look at the topic below, we discussed different types of rudder making/linkages in this topic.
If the link doesnt work for you, have a look for the topic headed '100th scale rudders'.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=6319.0
Hope this is of some help to you.
aye
john e
bluebird
Knowledge begins with respect
HS93 (RIP)
  • I cannot spell , tough
Re: Rudder Linkage?
« Reply #3 on: November 19, 2007, 04:38:56 pm »
If you dont want to make them try     http://www.deansmarine.co.uk/html/accessories.html    they make some with brass inserts. or
even    http://www.modelboatmayhem.co.uk/forum/index.php?topic=6500.0 another way of doing it.
Peter
Billyruffian
Re: Rudder Linkage?
« Reply #4 on: November 19, 2007, 04:47:23 pm »
Thanks for all you input it's been a great help - I am now sorted - thanks again all.
Page created in 1.876 seconds with 18 queries.
