Author Topic: Roman numerals on hull  (Read 13253 times)
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
« on: November 20, 2007, 03:18:50 pm »
On the plan that I am working from, I have one set of numerals at the bow, and another set at the stern.
(I - XVII)
Will they both be repeated on the other side of the hull? - four sets.
Re: Roman numerals on hull
« Reply #1 on: November 20, 2007, 03:49:16 pm »
Yes, although modern vessels are less likely to have Roman numerals if at all.
IainM
« Reply #2 on: November 20, 2007, 03:55:22 pm »
Hi Colin,
Yup ... these are the draft marks used to indicate the depth to which the hull sinks so the lowest numerals will be at the bottom.
As you say there will be one set on either side of the hull at the bow and the same at the stern.  To be pikkie, the ones at the stern may be positioned differently depending on the hull form.
Iain
sinjon
  • Sinjon
« Reply #3 on: November 20, 2007, 05:12:46 pm »
Thanks both,
I am building a 1/48 Dave Metcalf Bulldog, on his plan they are shown, I'll go with it.
I am not looking for an exhibition grade model so a little cheating is in the frame, I have 'transfers' but the markings are in pairs - Roman with serifs, Roman without - one pair of each, so port will be with serifs, stbd without, you will only see one side at a time, I can live with that.
Bryan Young
« Reply #4 on: November 20, 2007, 09:44:32 pm »
There are many instances of ships having 2 different kinds of draught marks. The "English" sort were (are) 6" high, so you had a base line at the bottom and a 6" line at the top, then a 6" gap to the next one. Reading the draught was then just a matter of judgement over a 6" spread. I guess the metric sort are similar but measured in decametres(?), same principle though. Give me feet and inches anytime!
Notes from a simple seaman
hama
« Reply #5 on: November 20, 2007, 10:40:47 pm »
Your right there Bryan. I can speak for the metric part of the world. Each figure is 1 decimeter high and the space between each figure is 1dm. As a mate you spend a lot of time on the dockside reading the drafts, as I remember it was always choppy seas and dark!!
Good night!
sinjon
  • Sinjon
« Reply #6 on: November 21, 2007, 10:18:07 am »
Sorry..... yet another thing, I have a black band at water level, are the letters white where they cross it?
Otherwise you can't see them.
« Reply #7 on: November 21, 2007, 08:01:39 pm »
Yes, that's what makes it expensive!
sinjon
  • Sinjon
« Reply #8 on: November 21, 2007, 09:14:49 pm »
I wonder if it would be feasible to cut some very fine white self adhesive strips, and make them up, after all they are only
    IIIIs  or  VVVVs  or XXXXs......hmmmm.  serifs could be a bit of problem though.
IainM
« Reply #9 on: November 21, 2007, 09:49:20 pm »
The markings at the water line are the 'Load Lines'
Given the size of the markings and the scale, it could be tricky to make or paint them, but if you have them as a transfer ....
If you're stuck you could make your own using water slide transfer paper etc., but I guess you know about this anyhow.
Iain
Arrow5
« Reply #10 on: November 21, 2007, 09:55:23 pm »
Nobody has mentioned the plastic stick-ons from BECC the flag people,includes Plimsol Line shown in last post, Roman or "modern" styles in black or white, or was that the expense bit ?
..well can you land on this?
« Reply #11 on: November 21, 2007, 11:00:16 pm »
That was the "expensive" bit. Two colours needed for each "run" of draught markings. But yes, the BECC ones are excellent. Just make sure your next boat has the hull colours the other way round and you'll make a saving!
GLASGOW WARSHIP TEAM
« Reply #12 on: November 22, 2007, 12:36:00 am »
cammett model ship fittings do a brass etch roman numerals set, that you can paint and then glue on.
sinjon
  • Sinjon
« Reply #13 on: November 22, 2007, 07:36:34 am »
Thanks GWT, had a look at their website but couldn't find them, sounds good.
Mailed them anyway. Awaiting reply.
Arrow5
« Reply #14 on: November 22, 2007, 09:38:31 am »
Can a section of the plastic stick-ons not be painted the opposite colour too ?
sinjon
  • Sinjon
« Reply #15 on: November 22, 2007, 09:59:56 am »
Hello Arrow5,
I have some small plastic alphabets.
Possibly applied, and then sanded down, to reduce the profile.
Do you have a source for Roman Numerals?
« Reply #16 on: November 22, 2007, 10:19:29 am »
hi there
Just as a quick thought, the railway people 'Slater's' do several 'fine scale' alphabets in plastic, these vary in scale.  They are reasonably priced too.   I got my last set from 'E-BAY' and I think it was something like £2 plus postage for two packs.   What I did with mine, I slightly sanded them down and then just painted them & stuck them on to the side of my model boat hull.
hope this is of some good help
aye
john e
bluebird
« Reply #17 on: November 22, 2007, 10:30:20 am »
That must have been a very fiddly job John. How did you avoid getting glue "overspill"? Otherwise, yes, the Slaters alphabets could be the answer. Squires sell them at 2mm to 6mm high starting at £2.65 a set.
« Reply #18 on: November 22, 2007, 10:41:55 am »
Just for you Colin and you are not to tell anyone else on this Forum  O0 I VILL ZAY ZISS ONZY VONCE  {-) {-)
Mark out the distance of your numerals from the first numeral to the last one - do this on a piece of clean scrap plywood.  Then, over the top of this, place a length of cellotape sticky side up.  Then onto the cellotape, start at zero sticking that numeral on reverse side up and carry on placing your numerals onto the cellotape, using the marks below on the plywood for the spacings between the numerals.
You then, with a cocktail stick, apply a dab of superglue on to each numeral.  Carefully, when this is done, remove the cellotape off the plywood and place it on the desired place on your model so that the glue comes into contact with the hullside, and then, once its dry peel cellotape off, leaving the numerals at the correct spacing on the model with very little overspill.  O0 O0
aye
john e
bluebird
sinjon
  • Sinjon
« Reply #19 on: November 22, 2007, 10:57:33 am »
Just had a look at Slaters and Squires lettering, I guess the same thing.
For 1/48, 3mm seems the closest, had a quick count and I think it could be done with three packs.
Applying them could be straight forward, if a little fiddly.
Mark the vertical spacing onto a strip of masking tape, stick tape vertically into position on the hull, and starting at the top mark, put a horizontal piece. apply letters along the horizontal tape, move tape down one space etc etc.
Gluing, possibly a spread of super glue on plastic and a pair of tweezers, fiddly but feasible. (I think)
« Reply #20 on: November 22, 2007, 11:01:57 am »
Ingenious John! Actually it has just occurred to me that maybe Slaters would not be the best answer for Roman numerals as you would need lots of "I" s and "V" s which could mean buying several sets.
sinjon
  • Sinjon
« Reply #21 on: November 22, 2007, 11:02:27 am »
John,
Whilst I was busy working it out, you slipped in before me, quite similar, but yours does sound a bit more straight forward. will get some letters and give both ways a try.
Sounds like a lot of fun for a whole day - thanks
colin
sinjon
  • Sinjon
« Reply #22 on: November 22, 2007, 11:17:34 am »
Had a quick count up, 23 IIIs   9VVVs  & 8XXXs
Forget the IIIs because you can cut down Ls Hs even 1111s.
There seems to be four VVVs & three XXXs to a sheet.
Three sheets per column, and FOUR columns on the boat,  again it looks expensive.
« Reply #23 on: November 22, 2007, 11:53:53 am »
hi there Sinjon
I have just rang Slater's and here is their phone number: 01629 583993
Extension number: 10
Spoke to a very nice lady there, she informed me they do not do purely Roman Numerals, but, if you asked no doubt they would come up with a little 'special deal' because you would be purchasing strips.
They do have a Website, if you google that.   But, it may be worth a telephone call.
aye
john e
bluebird
sinjon
  • Sinjon
« Reply #24 on: November 22, 2007, 12:24:00 pm »
Thanks John, I'll give them a call.
