Author Topic: modelling material(this is possibly in wrong place)  (Read 2495 times)
MTB
« on: February 02, 2008, 11:22:21 pm »
i am building a dockside scene :D to house some of static boat models but i've run up against a problem of findingwhere to get some of the materials. i have a couple of land rovers that i want to use as working vehicles around a boat yard and want to modify thembut can;t seem to track down anything that looks like checkerplate or corigated roofing or even tiled roofing. i know it exists because i used to use it years sgo when iwas into model railways with my grandsons,but where did i get from .pretty desperate so need your help. i'm aware of plastruct which i use a lot but this is not on thier websitecheers lads,roy mtb :kiss: :kiss:
Re: modelling material(this is possibly in wrong place)
« Reply #1 on: February 02, 2008, 11:30:48 pm »
Sounds like you need Slater's embossed plasticard. Have a look here:
http://www.expotools.co.uk/1723_1.html
Squires stock it too.
MTB
« Reply #2 on: February 03, 2008, 01:34:48 am »
 ::) ::) ::)thankscolin could be exactly what i need will have alook now.cheers.roy :P :P :BEEN THERE AND DONE IT GOOD STUFF COLINMANY THANKS roy.. :angel: :-X
bogstandard
« Reply #3 on: February 03, 2008, 05:29:28 am »
This is direct to the manufacturer, don't know if it is any cheaper, but you won't have any trouble of it being out of stock
http://www.slatersplastikard.com/Plastikard/slaters%20embossed_plastikard.htm
Got to bottom of the page to select next page. The downloadable pdf files on each page shows it all.
funtimefrankie
« Reply #4 on: February 03, 2008, 09:11:55 am »
Try model railway shops
alan colson
  • I Just Dabble In Model Boats
« Reply #5 on: February 03, 2008, 09:38:20 am »
try squires of bognor regis
« Reply #6 on: February 03, 2008, 09:41:46 am »
Yes, I mentioned Squires in my post. When I was in there just over a week ago they had a very big selection of the embossed plasticard in stock. Prices from £1.75 to £2.99 per sheet depending on the pattern.
MTB
« Reply #7 on: February 04, 2008, 03:56:56 pm »
thanks bog standard but i've been trying to down load the pdf file all weekend but it' won't work :-\ ??? and individually it will take forever. roy
« Reply #8 on: February 04, 2008, 04:27:11 pm »
MTB as Colin says try here. Goes straight to the page you want. O0
bogstandard
« Reply #9 on: February 04, 2008, 08:14:49 pm »
MTB,
Don't know if this helps.
