Author Topic: Damen axe bow fast crew supplier 3307  (Read 24952 times)
moller62
Re: Damen axe bow fast crew supplier 3307
« Reply #25 on: July 08, 2008, 10:48:47 pm »
Thx for the comment, including the "Balcony one"  8)
I aggree that the hull shape is interesting. I was actually a bit worried about the steering abilities of the vessel because of the deep bow. The vessel is however easily controlled, so mayby the deep stem acts as a pivoting point in the stearing process.
moller62
« Reply #26 on: July 08, 2008, 10:53:44 pm »
Nitty gritty, Fendering tires
This was an easy nitty gritty task, altough there's a discrepancy between the design and the actual vessel. Below is the designed fendering only featuring tires as fenders.
moller62
« Reply #27 on: July 08, 2008, 10:58:36 pm »
Silni
An actual vessel in this case the Silni has another configuration of fendering. The vessel is depicted below. Origen http://www.boatdesign.net/forums/attachment.php?s=4e8c51ba0204069074d4c0de50738cd2&attachmentid=13370&d=1179556670
moller62
« Reply #28 on: July 08, 2008, 11:04:09 pm »
I opted for the original configuration as tires was readily available at the local 'plastic kit pusher'.
The aft tires are spares for a lorry, whereas the small ones were meant for a Unimog.
moller62
« Reply #29 on: July 08, 2008, 11:12:12 pm »
Just another picture
I'm not sure whether the real vessel is named Silni form Split or Split from Silni  ::)
http://bp1.blogger.com/_2mOeKZzflVE/RcJKVV-MqMI/AAAAAAAAAUw/NCi_O-uqYlk/s1600-h/DSC02086.JPG
bobinnit
« Reply #30 on: July 08, 2008, 11:48:52 pm »
 Silni
2,200 HP, Crew Boat, Built 2007
REF:-http://www.clarksons.net/register2/register.asp?rOpt=register&rSel=0&showItem=1&search=Si&Page=1&x01_cvn=59424584 O0
moller62
« Reply #31 on: July 17, 2008, 09:51:23 pm »
No the wine is not French ;D
In fact i used Danish beer while performing the second sea trial at the local pond.
moller62
« Reply #32 on: July 17, 2008, 09:56:24 pm »
Laying calm on the waterline
No dangerous ducks in sight :D
moller62
« Reply #33 on: July 17, 2008, 09:59:46 pm »
Almost full (2/3) speed ahead :police:
moller62
« Reply #34 on: July 17, 2008, 10:11:58 pm »
Video available
A short video, not including ducks or beer  :), will be available at <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/uGpXBxQvOBg"> </param> <embed src="http://www.youtube.com/v/uGpXBxQvOBg" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
kno3
« Reply #35 on: July 18, 2008, 10:48:15 am »
Hi!
What's the advantage of this "axe bow", can anybody please explain?
« Reply #36 on: July 18, 2008, 04:11:17 pm »
The bow design cuts through the waves like an "axe".
It should make for a smoother less stressed ride.
moller62
« Reply #37 on: August 16, 2008, 12:55:05 pm »
Axe bow advantage
The Axe bow concept is specially developed for smaller high speed vessels. The aim of the design is to reduce vertical acceleration (bumping) of the vessel.
A conventional design will, in high seas, follow the wawes up and down, where as the axebow will cut through in stead. The Damen yard claims that for vessels of similair sizes, the vertical accelaration is reduced by 30%, thus enabling the Axe bow vessel to a higher speed in high seas without (to much)  bumping. A video from a sea trial can be found at http://www.youtube.com/watch?v=lcvq_Wp-nxQ
kno3
« Reply #39 on: August 16, 2008, 09:43:01 pm »
Thanks! Now it makes some sense.
Hagar
« Reply #41 on: October 07, 2008, 08:06:33 pm »
Den er sku fint Hr Møller!!
The attack of the Vallensbæk swan: is he still at it?
Did they ever get that jet ski back from the swan?
I rather like the look of the red one. Boat not swan!
moller62
« Reply #42 on: June 05, 2009, 10:31:29 pm »
New Axebow supplier
I'm actually in progress of building my new model.
I have published my work on the Danish forum: http://www.skalamodelskibe.dk/news.php
This is unfortunately in the Danish language, but thx to Google is available in 'proper' English as well.
Hope you enjoy.
Cheers from Copenhagen  ok2
Thread in Danish:
 http://www.skalamodelskibe.dk/forum/viewthread.php?thread_id=162
Thread in 'proper' ;-) English:
http://translate.google.dk/translate?u=http%3A%2F%2Fwww.skalamodelskibe.dk%2Fforum%2Fviewthread.php%3Fthread_id%3D162&sl=da&tl=en&hl=da&ie=UTF-8
Preview of the new build
