Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 33   Go Down
Author Topic: Name that plane  (Read 201407 times)
andrewh
Re: Name that plane
« Reply #25 on: July 15, 2008, 10:41:02 am »
Its an Avro 504, probably K but the split cowl means that it might have got a rotary in there!, in which case I couldn't guess the type letter, and it might be a field fit
Don't know where, but there seems to be a speedboat below - which I also don't recognise
Re: Name that plane
« Reply #26 on: July 15, 2008, 11:18:50 am »
Correct! - Avro 504K Science Museum, London
Avro 504K biplane D7560 with 130hp Clerget engine no. 52090;
The Avro 504 first appeared in 1913 and was in service with the Royal Flying Corps during WWI.
As early as November 1914, three 504s carried out a 'mass' bombing raid on German airship construction
sheds at Friedrichshafen. In 1915 the Avro was adapted for training duties and remained in this role until
the late 1920s.
This particular one which can be found on display in Making the Mordern World in the Science Museum
was made in 1917 inventory number 1920-52. [source sciencemuseum]
Re: Name that plane
« Reply #27 on: July 15, 2008, 11:21:50 am »
And before we move on......
RickF
Re: Name that plane
« Reply #28 on: July 15, 2008, 11:40:46 am »
How about this one?
"Fill 'er up - four-star!"
Rick
andrewh
Re: Name that plane
« Reply #29 on: July 15, 2008, 11:43:26 am »
Engine is a Napier Lion, which puts the boat in the 20s or 30s
Depending on fuel about 450 HP (80 octane stuff) to 1000 HP (potent brew) Schneider Trophy S6
For some reason "Miss England" leaps to mind
Re: Name that plane
« Reply #30 on: July 15, 2008, 11:50:15 am »
Correct, "Miss England".
Bowwave
Re: Name that plane
« Reply #31 on: July 15, 2008, 11:54:05 am »
This must have been a strange thing to fly especially with "Boats"?
Don't suffer from sea sickness or is it air sickness ?
Bowwave
Re: Name that plane
« Reply #32 on: July 15, 2008, 12:30:48 pm »
In the background, a Fieseler, Storch  maybe?
sparky
Re: Name that plane
« Reply #33 on: July 15, 2008, 12:57:36 pm »
Can't remember the name/type, but isn't it a Kriegsmarine autogyro, towed behind WW2 U-Boats for target spotting?
andrewh
Re: Name that plane
« Reply #34 on: July 15, 2008, 01:15:47 pm »
The gryocopter is a Flettner - can't remember its detail.
Used as over-the-horizon spotting for u-Boats - Sorry Gottfried, we had to dive, but thanks for the warning!
The plane filling up is interesting - it has a Siskin look, but is a 2 seater.
Its an Armstrong Whitworth plane, with one off their engines, and its carrying out tests on HP leading edge slats (the big hinge fairings under the top wing LE)
It looks also as if the fin has been made much higher - again because of the low speed regime its flying in
'part from that you have me stumped
RickF
Re: Name that plane
« Reply #35 on: July 15, 2008, 01:35:00 pm »
Yes - it's an Armstrong Whitworth. Want a clue? Maps connect both its purpose and name.
Rick
toesupwa
  • USA'd ex Brit
Re: Name that plane
« Reply #36 on: July 15, 2008, 02:37:55 pm »
Sorry Martin, the Sopwith Tabloid made an earlier bombing raid in WW1  :P
"On 22 September 1914, Tabloids mounted the first raid by British aircraft on German soil. In their most famous mission, two RNAS Tabloids flying from Antwerp on 8 October 1914, raided the German Zeppelin sheds at Cologne and Düsseldorf. The Cologne target was not located, the railway station being bombed instead, but the shed at Düsseldorf was struck by two 20 lb bombs dropped from 600 ft and the Zeppelin Z.IX was destroyed."
swordfish fairey
Re: Name that plane
« Reply #37 on: July 15, 2008, 02:55:14 pm »
That is a Fieseler Storch, but the Gyrocopter is a Focke-Achgelis FA330 Bachstelz (Wagtail) Rotor-Kite.Focke-Wulf built about 300 of them in about 1940. Took about 18 minutes to get into the air, but a heck of a lot longer to get back down to the U-Boat, hence not a success.  Just a guess,is it an Armstrong-Whitworth Atlas ?   O0......Smudge.
RickF
Re: Name that plane
« Reply #38 on: July 15, 2008, 05:01:12 pm »
Yes, Smudge, it's an AW Atlas.
Introduced in 1927, it was the first purpose-built army cooperation aircraft. The hook for ground-to-air message retrieval is just visible below the fuselage roundel.
Rick
andrewh
Re: Name that plane
« Reply #39 on: July 15, 2008, 05:08:40 pm »
I confess I cheated and looked up the plane Reg no and turned that up - but didn't want to pretend to know.
Re: Name that plane
« Reply #40 on: July 15, 2008, 05:18:20 pm »
OK, easy one.....
Re: Name that plane
« Reply #41 on: July 15, 2008, 05:30:33 pm »
Ford Tri-Motor?
Re: Name that plane
« Reply #42 on: July 15, 2008, 05:51:49 pm »
Nope.... so it must be.....  :)
Bowwave
Re: Name that plane
« Reply #43 on: July 15, 2008, 06:01:22 pm »
JU 57 ?
Bowwave
Re: Name that plane
« Reply #44 on: July 15, 2008, 06:28:26 pm »
Close.....
FullLeatherJacket
Re: Name that plane
« Reply #45 on: July 15, 2008, 07:02:15 pm »
Re: Name that plane
« Reply #46 on: July 15, 2008, 08:13:20 pm »
Junkers 52
Re: Name that plane
« Reply #47 on: July 15, 2008, 09:06:02 pm »
Correct - JU 52 - Tante Ju - "Auntie Ju" - http://en.wikipedia.org/wiki/Junkers_Ju_52
Re: Name that plane
« Reply #48 on: July 15, 2008, 09:12:46 pm »
No plane pics someone else will have to go next.
cos918
Re: Name that plane
« Reply #49 on: July 15, 2008, 09:42:48 pm »
ok what about this one
john
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 33   Go Up
