Author Topic: Marbleheads  (Read 6394 times)
BlueWotsit
Marbleheads
« on: August 16, 2006, 05:25:42 pm »
What type of servo is recommended for these.
Also can anyone give guidance on tuning the rigging
thanks
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Marbleheads
« Reply #1 on: August 17, 2006, 02:53:05 am »
Bluewotsit,
Any standard servo can be used in a marblehead for the rudder with no problems of any kind, but a winch servo is a must for control of the sails, there is a variety of winch servos around, I use GWS winch servos in most of my yachts with no problems, they are quite cheap and redily available...
Any other problems just holler..
Roy
martin-R
Re: Marbleheads
« Reply #2 on: August 18, 2006, 04:33:59 pm »
 Marbleheads have a lot of sail area and even the big GWS servo will be underpowered. The Hitec HS815BB Servo will serve you better, although I think winches are preferred to sail-arm servos for these.
BlueWotsit
Re: Marbleheads
« Reply #3 on: August 18, 2006, 04:45:24 pm »
From what Ive been reading this could be a difficult one to gauge as most people seem to have several sets of sails.
I agree that the winch is probably best
cheers
BlueWotsit
Re: Marbleheads
« Reply #4 on: August 18, 2006, 08:56:21 pm »
Update - Ive got a Hitec winch installed and working - now to try and find some instructions on how to connect all the rigging lines, etc theres several more than on yachts Ive used before !!
MikeK
  • Utter Bloody Chaos !!
Re: Marbleheads
« Reply #5 on: August 19, 2006, 09:05:17 am »
Hi BW
Try this site for a help on info including winch line paths etc.
http://www.onemetre.net/
I know it is for one metre yachts but all the rigging is the same. As mentioned above the sail area on a Marbelhead is far too powerfull for a sail arm to control, but i see you have got a winch so that's ok
There might also ]be some useful leads on the MYA site as well at www.mya-uk.org.uk
Best regards
MikeK
cbr900
    • Roys Hompage
Re: Marbleheads
« Reply #6 on: August 20, 2006, 02:01:12 am »
Martin,
The GWS winch is perfectly capable of operating the sails on a marblehead yacht with ease in any conditions we have about fifteen in our club that use GWS and no one has a problem, If you have had a problem maybe you had it set up incorrectly, I find that the hitec winch  will also work well but is better suited to an even bigger yacht...
Roy
martin-R
Re: Marbleheads
« Reply #7 on: August 20, 2006, 08:58:05 pm »
Maybe I'm thinking of the wrong type of servo. For my 950 mm Saphir, which carries little more sail than an IOM C rig, I use the Supertec SO4 http://www.sussex-model-centre.co.uk/shopexd.asp?id=880 , which I believed was a GWS design. Even with a 5 cell pack, it has problems in really stiff breezes (bft 5 - 6). Your recomendations for a GWS with more torque would be appreciated, as their prices are better than for similarly rated Futaba/Hitec.
P.S. I've just seen the S777 on http://www.servohut.com/HTML/heavy.htm That's a real giant of a servo but the price is a bit much for my budget >:(
cbr900
    • Roys Hompage
Re: Marbleheads
« Reply #8 on: August 23, 2006, 03:59:55 am »
The Winch Servo's that I am using are numberedS125 2BB, the seem to do the job well over here..
Roy
