Author Topic: TYPHOON LEMCA HYDRBRID BUILD  (Read 6500 times)
robbo770
« on: August 22, 2008, 06:35:47 pm »
 O0 {-) :o >>:-(
Well I have got my hands finally on a Typhoon all be a badly built one!, but stripped it back and reset the main hull sections and fibreglass the lower hull as flimsy of the standard model is an under statement!.
after must decision's, I have decide to list whats going into this one from the offset.....
Depth control ( only one in my book capable the Subtech APC1) Dave commission please!!!
pitch controller again From Subtech!
Special order Gyro heading lock auto pilot for maintaining course even when submerged!
Simulate ballast blow system on surfacing Gas blow to surface!!! for effects
All opening Ballistic misslie doors and at least 10 launching missiles by remote!!!
4 firing torpedo's own design as now in final stages of development
Remote raise and lower of periscope assembly
remote lights control for all markers
On-board 2.4 Mhz camera unit for real time piloting even submerged!!
on-board sound with waterproof speakers with engine sound for on surface to dive klaxon!!
opening and closing front plane doors
considering retractable sonar arrays x 2 for the rear pods
Propotionable bow thruster via Actions P94 super ESC and steering module (has to been seen to appreciated.)
Static dive by special order NORBERT BRÜGGEN dive Bag system
Special made to suit waterproof compartment for all electronics.
here is a photo of her in basic hull status at the moment, plane door already fitted.
thanks Rob
colin-stevens
Re: TYPHOON LEMCA HYDRBRID BUILD
« Reply #1 on: August 22, 2008, 07:43:28 pm »
go for it feller, but keep the faith
grumpy old XXX
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #2 on: August 22, 2008, 11:41:14 pm »
This ones going to be impressive me thinks  O0
das boot
« Reply #3 on: August 23, 2008, 04:42:23 am »
Good luck, keep the pics coming in.
Sub driver
« Reply #4 on: August 24, 2008, 09:02:27 pm »
I shall watch with interest
Regards Sub.
robbo770
« Reply #5 on: September 02, 2008, 06:00:11 pm »
Got some more work done in the twilight zone!!! :o :o
Here is the bow doors fitted, the upper to split decks now joined
and here is the new dive system
and here is the upgrade rough work on the rear towing arrays
and the lower strengthing and upper hull into 1 part for missile door fitment
and the begining of the work over of the conning tower
das boot
« Reply #6 on: September 02, 2008, 06:30:50 pm »
Looking good...plenty there to keep ya busy!!
Subculture
    • Dive-in to Model submarines
« Reply #7 on: September 02, 2008, 10:11:55 pm »
It's going to be a very long dive time with that peristaltic pump.  :o
Or are you using it for a trim cell?
robbo770
« Reply #8 on: September 05, 2008, 02:54:30 pm »
 O0
this baby will be almost zero bouyancy when complete due to all the gizmo's so won't need much to take her to the bottom so it should be fine,
thanks for the heads up though!,
Rob
Subculture
« Reply #9 on: September 05, 2008, 03:58:05 pm »
Gotcha- not going for a scale waterline then.
« Reply #10 on: September 05, 2008, 04:51:35 pm »
Can you tell us a bit about the pump please?
Martin
Subculture
« Reply #11 on: September 06, 2008, 12:55:19 pm »
I'll chip in here. The pump is a small peristaltic unit. It uses a 540 type motor,a low RPM and low current version. The pump can flow 220ml per minute, so it's really only suitable for small tanks. The advantages of a peristaltic pump are-  they are self sealing, they can pump either direction, they can pump relatively high pressure and they are relatively simple. Disadvantages? Not terribly efficient, slow and quite bulky compared to other designs of pumps.
More here-
http://www.modelluboot.de/Zubehoer/Sack.html
robbo770
« Reply #12 on: September 06, 2008, 07:45:01 pm »
I should get a scale water line with the floation foam added to bring her up, this will only just be to do that only, I am reducing and custom making all WTC for each required item so as much flooded area is involved as there is enough space in her for all the bits I want to put in her but not for the original tray set up so its a gonner!"
but that is months away as got much designing to get the 20 missile launchers in first to then work out where the bits are to locate inside the hull, nothing like a location lottery!!
Rob
Turbulent
« Reply #13 on: May 16, 2009, 06:30:50 pm »
Any updates on this ?
robbo770
« Reply #14 on: May 16, 2009, 08:01:40 pm »
I have been on recon mission in Dubai , just back  so should get back to her shortly!,
will update as I go.
Rob
Page created in 0.035 seconds with 17 queries.
