Pages: 1 [2] 3   Go Down
Author Topic: Borderer  (Read 18589 times)
MCR
Re: Borderer
« Reply #25 on: April 05, 2009, 10:47:26 pm »
ronkh
Re: Borderer
« Reply #26 on: April 06, 2009, 10:33:02 am »
It works! Lovely job, you have every right to be proud. :-))
kno3
Re: Borderer
« Reply #27 on: April 06, 2009, 03:27:03 pm »
Very nice. Now what are you going to power with the engine?
MCR
Re: Borderer
« Reply #28 on: April 06, 2009, 03:50:11 pm »
I plan t build the Wide A wake which is an open launch with clinker planking.
MCR
Re: Borderer
« Reply #29 on: April 15, 2009, 12:41:40 am »
Just added this:
Re: Borderer
« Reply #30 on: April 18, 2009, 02:56:14 pm »
Considering you couldn't open the file initially Mike, it must haave only taken a couple of hours from drawing to ON.
   Regards   Ian.
MCR
Re: Borderer
« Reply #31 on: April 18, 2009, 05:25:57 pm »
The drawing was what I had been waiting for Ian so once again thanks.
Mark
MCR
Re: Borderer
« Reply #32 on: May 07, 2009, 08:59:43 pm »
I have just pulled the hull from the mould and added the first coat of yacht varnish. I discovered a good site on lapstrake building (clinker ) it has been an interesting process to date.
steamboatmodel
Re: Borderer
« Reply #33 on: May 08, 2009, 12:40:36 am »
Can you post a link to the "site on lapstrake building (clinker ) ", please.
Gerald.
MCR
Re: Borderer
« Reply #34 on: May 08, 2009, 05:35:57 pm »
Bernhard
Re: Borderer
« Reply #35 on: May 09, 2009, 07:13:23 am »
hi.........Mcr you launch look great...........have you eny more photos of it
Regards Bernhard
Re: Borderer
« Reply #36 on: May 10, 2009, 06:45:52 pm »
Don't know if you went to Harrowgate Mike but there was a display by Bertinat's son of the whole collection of his dads engines including both versions of the Borderer and Marcher. Slide and piston valve types.   O0
MCR
Re: Borderer
« Reply #37 on: May 10, 2009, 07:47:30 pm »
This is the one :
Fab work and it only represents 2/3rds of the collection a true inspiration.
MCR
Re: Borderer
« Reply #38 on: June 09, 2009, 06:59:30 pm »
Made a little more progress most in mock up as I try moving stuff about.
The boiler is upside down as it sits in the hull a little better at the moment.
Bernhard
Re: Borderer
« Reply #39 on: June 09, 2009, 07:34:31 pm »
woow ,,,,what a boat..........you have don,,,,,,look so fine............................
Regards Bernhard
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Borderer
« Reply #40 on: June 09, 2009, 07:50:28 pm »
Wow, just beautiful. If you change your mind about this launch i've got first dibs on that boiler :-)). A true inspiration mate.
Greg
kno3
Re: Borderer
« Reply #41 on: June 13, 2009, 10:54:09 am »
Your hull turned out very beautiful!
MCR
Re: Borderer
« Reply #42 on: June 19, 2009, 08:40:40 pm »
After a little more effort I have completed the stern.
Bernhard
Re: Borderer
« Reply #43 on: August 26, 2009, 01:33:40 pm »
hi,,,,,,,Eny news with the launch,,,,eny more photos
Regards Bernhard
MCR
Re: Borderer
« Reply #44 on: August 26, 2009, 06:10:04 pm »
Thanks for the interest:
While I have been on holiday in the USA for the last three weeks this is the current progress,decks complete yellow wood rear deck which was Pear has been replaced as I didn't notice that I had mixed up the timber my son pointed this out after I had varnished the decks >>:-(
The foredeck is removable to give access to gas supply and the bulk head is still only a mock up,the flooring will hold the engine boiler etc. and is also removable.
Bernhard
Re: Borderer
« Reply #45 on: August 26, 2009, 06:14:51 pm »
Many Thanks..................what a great boat it is.......first class work you have don there
cant get enof photo of it,,,,,
Regards Bernhard
MCR
Re: Borderer
« Reply #46 on: November 22, 2009, 11:12:38 pm »
Turns out the boiler purchased from Ebay was soft soldered and sprayed with undercoat to hide the fact  <*<
So time to get the saw out to salvage some of the copper.
Once again with lots of help and support from Mick my mentor this is the result.
MCR
Re: Borderer
« Reply #47 on: November 22, 2009, 11:21:06 pm »
Boiler construction
kno3
Re: Borderer
« Reply #48 on: November 22, 2009, 11:29:00 pm »
Nice work. What diameter does the boiler have?
MCR
Re: Borderer
« Reply #49 on: November 22, 2009, 11:54:09 pm »
Five inches if you check the previous posts you can see that the original boiler was substantial.
Pages: 1 [2] 3   Go Up
Page created in 0.014 seconds with 16 queries.
