Author Topic: Manoeuvring astern  (Read 2335 times)
longshanks
Manoeuvring astern
« on: April 20, 2009, 11:05:57 pm »
Hi Folks,
Need some help. When manoeuvring astern with twin props, if I want the stern to swing to port (facing ahead) i.e the vessel will make a 'J' shaped course. Am I right in thinking that the inboard prop should be going ahead and the outboard prop astern? The model in question will have twin steerable kort noozles with integral rudder fin.
longshanks
Re: Manoeuvring astern
« Reply #1 on: April 20, 2009, 11:11:19 pm »
With twin Korts just steer with the thrust from the Korts.
Both props going astern steer to stbd will swing her to port.
« Reply #2 on: April 21, 2009, 03:09:55 am »
Manouvering as you suggest will tend to turn the boat clockwise in its own length (or so).
Doug
Bunkerbarge
« Reply #3 on: April 21, 2009, 10:26:19 am »
Would I not be right in thinking that, if you are using Korts, the tendancy for he stern to 'Creep' due to the prop rotation would be significantly reduced anyway?
Bryan Young
« Reply #4 on: April 21, 2009, 05:29:49 pm »
Sorry, but I just cannot understand the reasoning behind this post! Surely the answer is to put the boat on the water and play with it, using all sorts of combinations to find out what suits you and the boat best.
Having said that, I have a couple of large twin screw boats (cable repair ships) and find manouevring astern is the same as with full size ships. That is, stop one engine. If your props are "right-handed" then stop the starboard one and use the transverse thrust from the port one to push the stern to port. Using both props will turn the ship but about a more or less central axis. Play with it, but try just using the one engine. Cheers. BY.
Notes from a simple seaman
Page created in 0.775 seconds with 17 queries.
