August 10, 2025, 04:32:11 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
Graupner Voith unit
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Graupner Voith unit (Read 2613 times)
dms toucan
Guest
Graupner Voith unit
on:
November 06, 2009, 11:40:10 pm »
I need to put grease into the unit, how do you open it
without breaking it. Hope you can help
Regards Martin
poll
Full Mayhemer
Offline
Pontefract, West Yorkshire.
Re: Graupner Voith unit
Reply #1 on:
November 06, 2009, 11:46:38 pm »
Hi Martin
The water lubricates the unit, when you take it out of the water after a run, you should run the unit a couple of secs to empty the chamber. Hope this helps.
John.
Umi_Ryuzuki
Guest
Reply #2 on:
November 07, 2009, 09:57:24 am »
If I recall correctly,
Remove the belt from the drive pulley, then remove the small set screw in the top.
You can then unscrew the large drive pully from the unit's "drive shaft"...
It should just disassemble after that.
dms toucan
Guest
Reply #3 on:
November 07, 2009, 02:14:53 pm »
Thank you Umi
Regards Martin
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
Graupner Voith unit
