Pages: 1 2 3 4 [5] 6 7 8   Go Down
Author Topic: Friggin' in the Riggin' HMS Victory  (Read 85546 times)
JohnReid
Re: Friggin' in the Riggin' HMS Victory
« Reply #100 on: December 22, 2009, 02:28:31 pm »
Step 14 cont....
It is a single pendant of the type seen on the mizzen mast.
I will however try to find a reference and post it here.
A single pair of pendants is fitted around each of the fore and main topmasts immediately above the crosstrees,in the same way as the mizzen pendant.They are 5 1/2" rope.There is no topmast pendant on the mizzen.
__________________
JohnReid
« Reply #101 on: December 22, 2009, 02:56:35 pm »
Step 15 cont.....
These are fitted to the fore and main topmasts only,one each side, they are 7" rope with an eye going over the masthead and a 14" block tied into the lower end slightly above deck rail level.A 5" rope is tied to the base of the first deadeye on each channel except the mizzen ones,it runs through the block,and ties off to the base of the third deadeye on the fore channels and to the base of the second deadeye on the main channels.
JohnReid
« Reply #102 on: December 22, 2009, 03:13:17 pm »
Step 16 cont......
Three each side,of 7" rope.
JohnReid
« Reply #103 on: December 22, 2009, 11:41:58 pm »
Step 17 cont.....Three each side of 7" rope belay to the foremost eye on the backstay stool.
JohnReid
« Reply #104 on: December 22, 2009, 11:59:38 pm »
Step 18 cont....
One each side 4 1/2" rope leading to the forward eyebolt on the mizzen backstay stool.
JohnReid
« Reply #105 on: December 23, 2009, 03:26:06 pm »
Step 20 cont..
Same as fore backstay but the lower 12" blocks are tied to the main channel eyebolts between the ninth and tenth deadeyes.
JohnReid
« Reply #106 on: December 23, 2009, 03:43:53 pm »
Step 19.....cont..One each side 7" rope with a 12" double block tied to the lower end.12" single becket block tied to the foremost of the two eyebolts in rear end of fore channels.The blocks are joined by a 3" rope in a luff tackle,the fall being tied back on the eyebolt.
JohnReid
« Reply #107 on: December 23, 2009, 03:52:21 pm »
The first 20 steps are now finished.I will be posting all deck belaying points later.Cheers! John.
JohnReid
« Reply #108 on: December 23, 2009, 04:25:33 pm »
Step 21 cont...Same as the fore and main but using a 4 1/2" rope for the backstay and 9" blocks with the lower single one tied to the single eyebolt on the aft end of the mizzen channel.The blocks are connected by 2 1/2" rope.
JohnReid
« Reply #109 on: December 24, 2009, 02:07:56 pm »
Step 22 cont.....
Tie one 12 " single block to the base of the port knighthead.Tie one end of a 6 1/2" rope around the foretopmast head.The lower end is led through the hole in the port bee.A single becket block is tied to its end.The two blocks are connected with a 3" rope in a gin-tackle,with the fall around the knighthead.
JohnReid
« Reply #110 on: December 24, 2009, 02:26:57 pm »
Step 23 cont....
Tie a 12" single block to the base of the starboard knighthead.Rig the stay as in step 22 but using a 8 1/2" rope.Lead it through the hole in the starboard bee and connect the blocks with a 3 1/2" rope,belaying the fall around the knighthead.
JohnReid
« Reply #111 on: December 24, 2009, 04:38:31 pm »
JohnReid
« Reply #112 on: December 24, 2009, 08:33:06 pm »
Step 24 cont............
Using 8 1/2" rope rig the upper end using the same method.The lower end is tied in a loop around the foremast just under the supports for the top.Its free end is tied off to the deck eyebolt aft of the foremast.
JohnReid
« Reply #113 on: December 24, 2009, 09:13:59 pm »
Step 25
Hack P65
Long P223 Plan 6
6 1/2" rope is rigged around the masthead led down through the single block at rear of the foremast head and belays to the deck eyebolt.
JohnReid
« Reply #114 on: December 27, 2009, 10:43:00 pm »
Step 26 cont......Step 26
Mizzen Topmast Stay
Hack P65
Long P223 Plan6
5 inch rope tied once around the masthead just at the bottom of the supports,brought down behind the mainmast and tied off around it again halfway between the second and third mastbands below the top supports.
JohnReid
« Reply #115 on: December 27, 2009, 10:57:11 pm »
Step 27 cont.....
Step 27
Topgallant Shrouds
Hack P65
Long P233 Plan6
These are of 4" rope on the fore and main and 2 1/2"on the mizzen.
JohnReid
« Reply #116 on: December 27, 2009, 11:23:25 pm »
Step 28 cont.....
Fore Topgallant Standing Backstay
Hack P65
Long P233 Fig 178
One on each side for each topgallant mast.The pair on the fore are 4" rope and lead to the last eyebolt at the aft end of the forechannels.Those on the main are also 4" and lead to the rearmost eyebolt on the main backstay stools.Tose on the mizzen are 2 1/2" and lead to the rear eyebolt on the mizzen backstay stools.
JohnReid
« Reply #117 on: December 28, 2009, 01:05:30 am »
Steps 29 and 30.
Fore and Main Topgallant Shifting Backstays
Hack P65
Long P233 Fig 178
One on each side of fore and main topgallant masts only,not on the mizzen.The pair on the fore are 4" rope and have 7" blocks tied in their ends which connect in a luff tackle by a 2" rope to a 7" becket block tied to the last eyebolt on the forechannel.The fall belays around the base of the next deadeye forward.The pair on the main are also 4" rope ,with a 7" double block and a 2" lanyard,the 7"single becket block being tied by a short strop around the base of the first deadeye on the main backstay stool,lying inboard of it.The falls belay to the base of the same first deadeye.
JohnReid
« Reply #118 on: December 28, 2009, 01:33:45 am »
Step 31
Jib Stay
Tie a short length of 4 1/2 " rope around the jib boom at its outer end ,as a collar called the "jib traveller".To this collar tie a length of 4" rope and lead this through the top sheave of the starboard cheek block on the foremast head and down behind the mast .Tie a 9" double block in its end just above the level of the lower mast cap.Tie another length of 3" rope to the becket of one of the two blocks installed in the aft end of the foretop.Reeve the blocks in a luff tackle leading the fall down through the after hole in the foretop and belaying as in the belaying diagram.
JohnReid
« Reply #119 on: December 28, 2009, 01:35:22 pm »
Step 32
Foretopgallant Stay
Tie one 8" single becket block to the port knighthead.Tie a 4 1/2" rope at the collar of the foretopgallant mast,knot it around the outer end of the jib boom,lead it back towards the port knighthead ,and tie an 8" double block in its end.Connect the two blocks in a luff tackle with a 2 1/2" rope,belaying the fall around the knighthead.
JohnReid
« Reply #120 on: December 28, 2009, 01:49:49 pm »
Step 33
Main Topgallant Stay
A 4 1/2 " rope leading from the main topgallant mast collar,down through the block attached at the rear of the foretopmast head,and tied off to the strop on the foretop behind the mast.
JohnReid
« Reply #121 on: December 28, 2009, 02:09:57 pm »
Step 34
Mizzen Topgallant Stay.
A 3" rope from the mizzen topgallant mast collar,down through the hole in the mainmast cap.It is tied off to the strop on the maintop behind the mast.
JohnReid
« Reply #122 on: December 28, 2009, 02:43:07 pm »
Step 35
Flying Jib Boom Horses.
Double ,made as the jib boom horses and running from the outer end of the flying jib boom to tie again around the same spar just aft of its support on the jib boom end.
JohnReid
« Reply #123 on: December 28, 2009, 02:58:19 pm »
The first 35 steps are complete except for the belaying points of each rope.Somewhere down the road I plan to make a belaying point diagram for each step shown here.
From now on each step will be completed as fully as possible before moving on to the next step.It is just too much of a hassle to come back and edit the information later.
Anyone using my rigging plan would already have many months of work before them just to bring their ship to this stage.
If everything goes as planned I am hoping to add about a step a day on average.
Good luck! Cheers. John.
JohnReid
« Reply #124 on: December 28, 2009, 04:31:56 pm »
Please note: the decision to use harbour,furled or full sail rig has to be made very early in the process .I plan to discuss some of the full sail rigging options later.
Pages: 1 2 3 4 [5] 6 7 8   Go Up
Page created in 0.284 seconds with 15 queries.
