Author Topic: Old type Futaba plug  (Read 3215 times)
Timo2
« on: February 28, 2010, 11:59:46 am »
Hi All
   Look for two ( 2 ) old type Futaba plugs ( Pin ) to fit FP-R2GS,
   Timo2
P.S.
   Trying  to help young lad ( 12 ) for his first Model  :-))
FullLeatherJacket
Re: Old type Futaba plug
« Reply #1 on: February 28, 2010, 12:10:45 pm »
Might be able to help. Got any cupboards?  %)
FLJ
Inkmark
« Reply #2 on: February 28, 2010, 12:48:52 pm »
Timo
Can I ask what you want the plugs for? I have lots of old Futaba stuff in the loft
and it would help if I knew what you want.
Mark
Timo2
« Reply #3 on: February 28, 2010, 07:04:07 pm »
Hi Mark
   The old pin type   eg.    O0
          Timo2
« Reply #4 on: February 28, 2010, 11:15:34 pm »
Timo2
I think I have a couple still with servos on, any use?
« Reply #5 on: March 01, 2010, 10:52:09 am »
I "converted" one using pins made from nickel silver wire (handrail wire left over from railway modelling).  The small offset was no problem - it just gave a bit of tension that ensured good contact.
Just a case of cutting three bits of wire about twice the pin length, inserting them into the RX socket holes, et voile, an RX with pins to plug an up to date device.  Repeat for the other channel.
It is possible that the RX, because of its age, does not possess the same selectivity as a modern one ( theres lots more "legal" channels squeezed into the same bandwidth today) so it MIGHT suffer from cross-channel interference.
Inkmark
« Reply #6 on: March 01, 2010, 05:43:16 pm »
Timo2
Like Phil I have a number of servos and switch harnesses.
Would be a shame to chop the plugs if we can help with the stuff you want.
Mark
Timo2
« Reply #7 on: April 13, 2010, 09:46:44 am »
Thank You All
    and a big THANK YOU to   Steamboatphil    :-))
    Good to meet  on Sunday at South Shields show
    Timo2
BarryM
« Reply #8 on: April 13, 2010, 10:59:28 am »
FLJ
Well that's your Medi Cruise cancelled for this year!  {-)
Barry M
Page created in 0.646 seconds with 17 queries.
