Author Topic: FLASHSTEAM ENGINE.  (Read 5413 times)
ooyah/2
FLASHSTEAM ENGINE.
« on: July 10, 2010, 10:13:20 pm »
Here is an engine that I built some years ago which is heavily influenced by A.W.Martin and although now no longer with us I believe has a son who still runs flashsteam engines .
I have found a site( www.on the wire.co.uk) which has some great reading for those interested in flashsteam. it lists all the great guys of steam !
I was greatly impressed by Mr Martins engineering skill in building lightweight flash engines so this engine is virtually a copy and from memory it weighed 1.25 lbs.
The boiler is made from A. Raymans drawing which is available I think fro TEE publishing.
It has 9 x 1/4" o/d coils on the underside with the tubes flush to the inside of the boiler and then having a complete 360 deg turn and back up into the boiler with the end of the tube up in the steam space, there is 3 ft of super heat tube coiled down into the path of the burner flame.
Boiler was hydraulic tested to 400 psi with no problems, the engine runs at 150 psi and the burner easily can keep producing steam.
The engine runs free at 10,000 rpm but I have never had it in a boat.
Water pumps and oil pumps are all engine driven and the burner is fueled with Paraffin from a 60 psi tank.
Having found this site many years later I discovered that Mr Martin was a Scot born in Glasgow, my home town so it's a bit of a coincidence  after all these years to find that we had a common interest.
George.
HS93 (RIP)
  • I cannot spell , tough
Re: FLASHSTEAM ENGINE.
« Reply #1 on: July 11, 2010, 02:17:36 am »
very nice, have you got any information or drawrings /sketches of the water pump on the back of th engine I like the way it is both a hand and mechanical pump with I presume only one set of valves.
peter
steamboatmodel
« Reply #2 on: July 11, 2010, 05:11:42 pm »
"I have found a site( www.on the wire.co.uk) which has some great reading for those interested in flashsteam. it lists all the great guys of steam !"
I can not find that site?
Gerald.
HS93 (RIP)
« Reply #3 on: July 11, 2010, 05:26:14 pm »
this link works no gaps  http://www.onthewire.co.uk/
peter
ooyah/2
« Reply #4 on: July 11, 2010, 10:30:52 pm »
Hi Peter,
Thank's for correcting the web site it was my mistake to put in the spaces.
If you PM me I will send you some sketches of the pump, they will not be scale drawings but will enable you to make one if you wish.
George.
ooyah/2
« Reply #5 on: July 13, 2010, 12:22:20 pm »
Hi Peter,
Just to let you see what can be done with ball valve pumps here are some picks of a "V" twin engine that I built and put on the pump driven by an eccentric sheave and it works very well.
If you don't already have them I would recommend 2- books x K.N.Harris.
Model Boiler Making and Marine Steam Engines.
In these books are a wealth of information for the model maker, just thought I would list them before I go on holiday down to the Lake Distric.
George.
HS93 (RIP)
« Reply #6 on: July 13, 2010, 01:38:17 pm »
very nice,What do you use it in ?
 I may have the KN Harris books I am in the middle of moving all my books about and having a clear out i cannot find the good stuff for the c***
peter
ooyah/2
« Reply #7 on: July 14, 2010, 11:44:44 pm »
Hi Peter,
I don't use it , I made it for a friend,
George.
Page created in 0.438 seconds with 17 queries.
