Author Topic: Stuart Boiler with Puffin Engine - Help required  (Read 15762 times)
KBIO
Re: Stuart Boiler with Puffin Engine - Help required
« Reply #25 on: October 31, 2010, 07:54:34 pm »
hELLO§ :-)
I have the same problem that Peteg220! <:( No way to switch on my Stuart burner! :(( I have to pull the ceramic burner off the boiler, switch on fire and stick it inside to have it burning! O0 I try with & without cheminey, warming up the cheminey! I tried evrything!
I don't know! <:( I have no problem with my other Stuart! >>:-(
Also, if I push the burner at the end of its palce, it sounds like a "flute playing"! Also, it takes me 20 min to reach 1 Kg with a big jet!
I'll try again tomorow! Maybe tyhe night will bring me a solution!
steamboatwilly
« Reply #26 on: October 31, 2010, 08:51:02 pm »
I do not use a ceramic burner. I use a 10mm ring of copper tube, 16 holes @1.5mm drilled around the top. Copied from the gauge 1 model railway boys that I made a boiler for.
Just google IDRIS and you can download for free. Hope this helps.
steamboatwilly
« Reply #27 on: November 01, 2010, 08:53:11 am »
Page created in 0.015 seconds with 15 queries.
