Author Topic: Which steam engine for a beginner  (Read 8621 times)
« on: September 30, 2010, 10:16:41 pm »
just stole a midwest fantail kit on ebay ($50 US including postage) and was wondering what engine would be better
the kit reccomends this one
http://www.cornwallmodelboats.co.uk/acatalog/midwest-model-iv-steam-engine.html
but as a first steamer would i be better getting this one?
http://www.cornwallmodelboats.co.uk/acatalog/midwest-heritage-steam-engine.html
I understand these need to be hand started would it be possible to start one of these with a small electric motor?
Also is it possible to use a servo to control the regulatator?
any suggestions greatly recieved
steamboatmodel
Re: Which steam engine for a beginner
« Reply #1 on: September 30, 2010, 10:58:21 pm »
That was a steal.
The first on comes as a kit and you have to solder everything together,  It’s not that hard to do, I have this one and hard (Silver) soldered it together. I have also installed a safety valve, the Wilesco one fits in the fill fitting.
The second one comes pre soldered and assembled and does have a safety valve installed.
Neither one uses a regulator, and there is no direction control, once you start them you just use rudder.
Having said that I think that you could rig up a couple of small motors to change direction, you normally just give the flywheel a flick in the direction you want to go. The other alternative is either a Kitchen Rudder (that’s what I am doing) or a variable pitch prop.
Gerald.
« Reply #2 on: October 01, 2010, 06:35:27 am »
Thanks for the reply :)
Are there any other suitable alternatives with a regulator or could a regulator be added to the 2 above?
bbjs
« Reply #3 on: October 01, 2010, 07:44:06 am »
How about a Regner Micro ?
http://www.regner-dampftechnik.de/aktuelles/neuheiten2010/40510_micro_dampfanlagen.php
...or a little bit of overkill, the full monty w. twin osc, gas tank, regulator, burner, Regner Mini:
http://www.regner-dampftechnik.de/aktuelles/neuheiten2005/dampfm_mini.php
Cheers, Bjorn
HS93 (RIP)
  • I cannot spell , tough
« Reply #4 on: October 01, 2010, 07:52:26 am »
I am not a fan of the standard mid west setup as you will get board and probably put of steam very quickly, it is not worth fitting a regulator as they are not very powerfull and not self starting so if you slow it down and it stops thats it  the plants posted by bbjs are a far better proposition , yes they are more expensive but will give you a better idea of steam and will last a long time.
peter
kiwimodeller
« Reply #5 on: October 01, 2010, 10:33:38 am »
I have seen a steam plant that can be restarted in either direction by a small electric motor but you also need a battery pack and either a speed controller or two micro switches operated by a servo. Plus you have to have another channel on the radio to work it. All a bit of an overkill for a small and simple model such as you are starting with. Better to use one of the engine and boiler setups reccommended and just enjoy what you have then be prepared to build something a bit bigger and more complicated, I am sure you will be hooked once you have run the Fantail a few times. Even though I have several steam boats I still enjoy taking the simple ones to the lake regularly. Good luck, Ian.
Timo2
« Reply #7 on: October 01, 2010, 02:07:30 pm »
Hi
    Have a look at     http://www.pmresearchinc.com/store/product.php?productid=3650&cat=4&page=2
        http://www.modelboatmayhem.co.uk/forum/index.php?topic=9960.0
      Timo2
bbjs
« Reply #8 on: October 01, 2010, 05:29:32 pm »
Is that self starting?
No, 1-cyl engines aren't.
You need a twin for self-start.
Though, the micro has a small built in lubricator and a steam valve.
Quite good value for the money I belive, but all depends how much you're prepared to pay....
Steam tends to be a quite expensive hobby, but fun !!!
The mini (twin) is self-starting and a much more complete setup for R/C. Can quite easily add a feedwater pump for extended runs.
AFAIK it's actually based on the good old Cheddar Plover (Pintail when a V), a very well running design.
At almost 500 Euro it's a different investment though, but well worth it IMHO.
Check this thread for some experience with the twin (here with a larger boiler):
http://www.modelboatmayhem.co.uk/forum/index.php?topic=15648.0
Cheers, Bjorn
« Reply #9 on: October 02, 2010, 10:47:43 am »
Ok so once a single has stopped rotating it needs to be restarted by spinning the flywheel in some way?
The Regner micro looks like the war forward for me andI have a idea and Im not sure if it would work, the theory seems sound enough tho:-
Could I fit a centrifugal clutch in the drive train so that when the engine revs drop below a certain RPM then the prop is disengaged allowing for a full stop. Similar to the way IC RC car drivetrains are setup?
« Reply #10 on: October 12, 2010, 12:29:56 pm »
Anyone know where I can order a regner micro?
« Reply #12 on: October 12, 2010, 04:03:40 pm »
 Looking at the original post request, you're delving deeper into the realms of advanced operations rather than beginner. Slowing a simple oscillator is not an option as it's too easy to stop it. If you require the stop/start functions you let the engine do its own thing and fit, as Gerald has already suggested, a variable pitch prop. This will give forward/reverse and all points in between with up to full speed in both directions.
 Only time you "Regulate" a single is at the pondside when generating steam.
