Author Topic: Battery maintenance  (Read 9258 times)
grasshopper
    • A1 Hobbies Ltd.
Re: Battery maintenance
« Reply #25 on: October 20, 2010, 11:43:49 pm »
My venom charger (over-priced Imax) came with a 5 Amp / 12v laptop psu as the mains supply - as long as the voltage from your 18v unit drops on load to around 12 to 15 v it should be okay if the current rating is up to it.
Check the polarity of the co-axial plug before you switch it on though.
pomybill
« Reply #26 on: March 20, 2011, 09:50:50 pm »
I have recently acquired a Venom charger but no info as to how to operate same . is there any way I can obtain some readable instructions as to how to operate this unit.
It has got several leads and wire connectors for the usual array of batteries but that is all.
Has any one a copy of the instructions please..
« Reply #27 on: March 21, 2011, 06:37:06 am »
Would have helped if you had specified which Venom charger you have.
Try here and scroll down to chargers.
http://www.venom-group.com/manuals.asp
Hope this helps  :-))
« Reply #28 on: March 21, 2011, 07:22:30 am »
Can the iMax B6 be powered by a laptop power unit, max 18 volts?
Im not sure..... Im running mine on a laptop PSU but its 14V
RaaArtyGunner
« Reply #29 on: March 22, 2011, 03:47:29 am »
My laptop power supply says
AC adapter for Toshiba output 15V, 8A  (made in China)
« Reply #30 on: March 22, 2011, 06:02:12 am »
Should be fine, im using a toshiba one as well
Page created in 0.547 seconds with 17 queries.
