Author Topic: Widening 3mm slots to 4mm  (Read 3493 times)
Dekan
« on: February 02, 2011, 07:53:51 pm »
I have acquired model kit... all the formers have 3 mm slots... but the wood is 4 mm thick. :o
I could have used a file... but can I find a 4 mm wide file..No.... Its not a dimension that anybody quotes.... Length, height but no width :((        Anybody got any ideas?
dbninja
Re: Widening 3mm slots to 4mm
« Reply #1 on: February 02, 2011, 08:27:13 pm »
so...    set up your CNC Router with a 4mm  Diameter cutter, clock your centres on the X-Y axis..    whats your problem?  :} :}
seriously
just make a sanding board of the correct thickness, use scrap 3, 3.25, 3.5mm with a layer of double sided tape and emery cloth and set too :-))  the sand paper tends to be more forgiving than a file and doesn't splinter the wood as much
i have the same problems trying to insert new pieces of ply into my old Aerokits fleet when i am restoring them, and no i haven't found a scource for old imperial unit ply.....   despite what the model shop calls it
db
guitar man
« Reply #2 on: February 02, 2011, 08:41:04 pm »
Hi Dekan
          Needle files are very thin though I find that wood tends to clog them up I believe you can get Tungsten carbide ones which may be better, but as Dbninja said a sanding board works for me
Dekan
« Reply #3 on: February 02, 2011, 09:05:22 pm »
I have thought of making up a sanding tool, but I thought there might be something else I hadn't thought about out there :}
« Reply #4 on: February 03, 2011, 03:35:26 am »
Permagrit do slot cutters. They are 3mm but be used to open out the slot.
They also do a flat file.
They are in the expotools.com catalogue p44-45
RickF
« Reply #5 on: February 03, 2011, 09:38:09 am »
I would try and obtain a round file tapering from less than to more than 4mm. Drill a 4mm hole in a piece of brass to make a collar then force this onto the file. This will automatically stop the file when the slot is 4mm wide. I have used this technique to make identical slots in plasticard - no reason why it should not work on wood, provide it is not too thick and the file is kept unclogged.
Rick
Nige52
« Reply #6 on: February 04, 2011, 09:56:55 am »
As nobody else has asked........just what kit is it that supplies things like this?
Also can you not file the tongue down 1 mill instead of widening the groove 1 mill?
Nige
Dekan
« Reply #7 on: February 04, 2011, 05:05:34 pm »
An Aerokits style kit, with 4mm ply bulkheads and 4mm keel and deck supports..... {:-{
Page created in 0.376 seconds with 17 queries.
