Author Topic: I Learnt a valuable lesson today  (Read 3214 times)
Boatbuilder2011
« on: June 15, 2011, 04:28:44 pm »
I learnt such big lesson today one I won't repeat again :( I decided to go to our club pond still as a new member I don't no the code to the rescue boat so I put the pt boat in water took it out to the centre of the lake and bank me being an idiot didn't super glue or thread lock the prop on :( stupid mistake I no having no momentum and no way getting the rescue boat on the water as it's chained down I started to panic I was thinking of what I had in the car to help and found a tow rope and tennis ball after 30 mins off throwing it out and gently bumping it against the boat I finally got it in big time lesson learnt :( has any one else ever done anything like this
Re: I Learnt a valuable lesson today
« Reply #1 on: June 15, 2011, 05:20:29 pm »
Seen this a few times before. Screw threads are normally RH threads so having a prop that screws onto the shaft clockwise when looking at the shaft end means that to ensure the prop stays on, the shaft should rotate anti - clock so you need a prop that generates thrust when rotating anti - clock.
  Before anyone jumps in with "It's a PT boat, so multi propped", retrieval wouldn't have been a problem, one of them would have been going the "Right" way.
  For the clock rotation fraternity, a locknut on the shaft in front of the prop would not go amiss.
nhp651
« Reply #2 on: June 15, 2011, 05:47:02 pm »
easily done, boatbuilder........you won't be the last.
after my first time with an expensive large prop i for ever after lockeked it up with a backing nut and then drilled through the propeller boss and secured it with a small split pin made from thin brass wire.never lost another since.
neil.
triumphjon
« Reply #4 on: June 15, 2011, 07:58:05 pm »
think most modellers have at some time either lost or broken a blade or more from a prop , mine are all locked to the shafts with the locking nut .
RaaArtyGunner
« Reply #5 on: June 15, 2011, 11:16:20 pm »
neil.
john s 2
« Reply #6 on: June 16, 2011, 03:31:21 pm »
Yup. I lost the prop on my first boat. Did what a well known boat shop said, (do it up tight) Lost it of course.
Now use a lock nut.. Did the shop know id lose the prop and buy another?. John.
