Author Topic: its my BLUE MORPH and BRAVE FISHERMAN...  (Read 5571 times)
rathikrishna
« on: August 27, 2011, 07:32:32 pm »
Firends..i almost stopped kit building for many years, but now i got two lovely boat kits from my Country. i am thanking one of the respected Senior, in my Country for these kits.actually at beginning my intention was to complete the craft as it was.but after completion of the hull structure i decided to add some of my imagination on to craft..and thus my Blue Morph and Brave fisherman born..
i got these kits intact..thanks for the best packing..
rathikrishna
Re: its my BLUE MORPH and BRAVE FISHERMAN...
« Reply #1 on: August 27, 2011, 07:35:10 pm »
the kit was simple but elegant..
i took about 20 minutes almost to complete the hull and started with polyester putty..
rathikrishna
« Reply #2 on: August 27, 2011, 07:37:19 pm »
started from keel..and bulkheads..its all simple..i ever seen..
rathikrishna
« Reply #3 on: August 27, 2011, 07:39:44 pm »
hull taking shape..
rathikrishna
« Reply #4 on: August 27, 2011, 07:41:58 pm »
top paving..
and gap filling with polyester putty..
rathikrishna
« Reply #5 on: August 27, 2011, 07:45:06 pm »
so after drying the poly putty, i started with nitro cellulose putty..
finished..up to this moment my intention was to complete the craft according to the instructions..but i added my imagination..to it..whats a craft without some imagination and personal touch..
rathikrishna
« Reply #6 on: August 27, 2011, 07:47:21 pm »
so i started with my own idea..started to adding trimming strips and splash strips..
rathikrishna
« Reply #7 on: August 27, 2011, 07:51:30 pm »
the prop shaft and tube was made out of a radio antenna tube, and from a bicycle spoke.
rathikrishna
« Reply #8 on: August 27, 2011, 07:54:15 pm »
my first decision was to use my home made brush less motor, but its too powerful and some big in dia, and the hand made ESC also some big..so space was a problem..so i added a tiny brush less motor on to craft..
rathikrishna
« Reply #9 on: August 27, 2011, 07:55:42 pm »
so i added a dummy engine to hull..it also acts as a rudder..
rathikrishna
« Reply #10 on: August 27, 2011, 07:57:44 pm »
added a micro servo to actuate the dummy engine as a rudder..an easy connector was fixed for easy fine tuning..
structure is almost complete..
rathikrishna
« Reply #11 on: August 27, 2011, 07:59:33 pm »
added a kort nozzle, and it saves my battery life to a great extent..
it also acts as a froth and bubble generator..
rathikrishna
« Reply #12 on: August 27, 2011, 08:01:33 pm »
now time to painting..i used inexpensive enamel paints and applied with hand brush..
rathikrishna
« Reply #13 on: August 27, 2011, 08:03:40 pm »
the whole window channels were made out of drawing paper and seasoned..
rathikrishna
« Reply #14 on: August 27, 2011, 08:05:25 pm »
painted in aluminum paint..
now with decals..
rathikrishna
« Reply #15 on: August 27, 2011, 08:08:04 pm »
painting in detail..
rathikrishna
« Reply #16 on: August 27, 2011, 08:09:34 pm »
angles..
rathikrishna
« Reply #17 on: August 27, 2011, 08:11:21 pm »
all bollards were made out of ear bud shaft, with brass welding rods..and painted in aluminum paint..
rathikrishna
« Reply #18 on: August 27, 2011, 08:13:32 pm »
now the Brave fisherman..actually this figure is from the ww2 German infantry set, but reworked some with my needs.
now time to run..
rathikrishna
« Reply #19 on: August 27, 2011, 08:15:43 pm »
in water..i left her in sea canal..and controlled by a 2.4 GHz 4 channel radio, with 30 Amps ESC with 1000 rpm /volts BLDC...
rathikrishna
« Reply #20 on: August 27, 2011, 08:17:16 pm »
showing the froth generator mode..its pleasant to see..
rathikrishna
« Reply #21 on: August 27, 2011, 08:18:46 pm »
showing the high performance mode..
rathikrishna
« Reply #22 on: August 27, 2011, 08:19:54 pm »
aqua planing..
rathikrishna
« Reply #23 on: August 27, 2011, 08:24:33 pm »
in hands of Gokul my ever favourite ship and aero model student..he is a nice rider..
showing the froth generator set up..its simple, and all we know how it works. a simple silicon tube is fixed just behind the prop, and a second hole is placed just after the prop.while accelerating the fresh air from outside, sucked in to the venturi, and atomizes with sucked water. so we will get a nice froth and bubbles..yes, reduce the performance to a slight extent..but a pleasant view to see...
rathikrishna
« Reply #24 on: August 27, 2011, 08:26:37 pm »
in detail..
Page created in 0.322 seconds with 15 queries.
