Author Topic: Rosegarth Next Project  (Read 3219 times)
steamshed
« on: December 04, 2011, 09:28:53 am »
Hi All
My next build project
HS93 (RIP)
  • I cannot spell , tough
Re: Rosegarth Next Project
« Reply #1 on: December 05, 2011, 04:22:17 am »
a very nice steam plant, it's notvery often you see pumps on them they work well, have you had the plant from new? it should push the tug well.
Peter
steamshed
« Reply #2 on: December 05, 2011, 06:51:14 pm »
Hi Peter
No I recently bought if from a gentleman who had it built by Cheddar for the Peggy, which he sold having never built it or used the plant, other than test run it  to see how the water pump worked into a tank.
My plan is the Rosegarth with onboard tanks!!
HS93 (RIP)
« Reply #3 on: December 05, 2011, 08:22:05 pm »
have you got the instructions for the pump , if not I have a set somewhere, and for the rest of the plant.pm me a email and ill send them as they are not very good when put up on hear at 180 k
Peter
Misty
« Reply #4 on: December 06, 2011, 09:03:39 pm »
Hi I see you have a cheddar attenuator on this set up. I would be interested to see how you get on with it. I have just purchased a boat with a loose attenuator and am wondering wether to reinstate it.
regards
David
HS93 (RIP)
« Reply #5 on: December 07, 2011, 02:03:59 am »
If you are new get use to sailing without it first, the problem is you have to leave them with the adjuster unscrewed to stop damaging the rubber membrane if it has been left in the wrong position it may well be inoperable.and you will have nothing but trouble trying to get it working to my knowledge you cannot get a new diagram for them from Stuarts. if you want that sort of thing go for the GAV unit sold now by Stuarts to the Cheddar design by far the best one to use and simple to operate.
Peter
Misty
« Reply #6 on: December 07, 2011, 12:31:22 pm »
Thanks Peter I will try it with a GAV I have spare.
David
steamboatmodel
« Reply #7 on: December 07, 2011, 02:15:00 pm »
I looked at Stuart Models and could not find a GAV unit. Are you reffering to a Electronic gas valve ? http://www.stuartmodels.com/accessories.cfm/mainaccess_type/9/the_type/Electronic%20Gas%20Valve
Gerald.
HS93 (RIP)
« Reply #8 on: December 07, 2011, 02:26:47 pm »
Gerald.
my Mistake I meant EGV
Peter
Page created in 0.528 seconds with 17 queries.
